WLC5508(v.7.0.235)- All of SSID disable auto after enable feature LAG
We have configure Ether Channel on Core switch. And then enable feature LAG on wireless lan controller after that WLC will be reboot. and then reboot finished, I saw WLAN menu SSID Admin Status was "Disable" all of SSID.and Interface of SSID changed to interface management. I want to know why have issue. ???
This is the expected behaviour when you creating LAG on a controller where WLAN already being defined. Please see the following document for your reference.
https://supportforums.cisco.com/docs/DOC-20587
  • When you enable LAG, all dynamic AP-manager interfaces and untagged interfaces are deleted, and all WLANs are disabled and mapped to the management interface.
If this answer to your query pls mark this thread as answered.
Rasika
**** Pls rate all useful responses ****
Did you able to manually enable the SSID & change the dynamic interfaces of your WLAN ?
Is it working or you have issues with it ?
Rasika
Yes , I can manual enable the SSID. and It's working everything. But my customer want to know cause admin status of SSID auto disable after enable LAG.
Rasika
Thanks so much Rasika
