WLSE and Patches
dhickey
Wejust received our WLSE 2.5 and I noticed a couple of patches on CCO.
Are the patches cumulative?
Do I have to install WLSE-2.x-CSCsa06658 then WLSE-2.x-CSCsa11583?
Or does the second patch include the first?
Don Hickey
minie
Level 4
Level 4
These patches are just for the particular bug fix. So, no they are not cumulative. However, check the readme first, you may not run into CSCsa06658 in which case you don't have to apply it.
rmushtaq
Level 8
Level 8
Each patch is for a specific issue as listed in the respective Readme file. Have a look at the Readme file first and then decide whether you need to apply the patch or not. Also, these patches are Not cumulative.
dhickey
Thanks for the info!
Don
