6.4 monitor interface
ADP_89
Hello Guys,
I was playing around a little bit with the new ASR9901 running the 6.4 version and I noticed that the command "monitor interface XXX" which previously was showing the packet/byte rate is not available anymore. I have tried to lookup into the documentantion but the "Implementing Performance Management" doesn't list it anymore.
Does somebody know if there is another way to get that output on 6.4? It was pretty handy TBH...
Thank you,
ADP
Do you have the 6.4.1 manageability (MGBL) package installed and active?
I believe this command is part of that.
5 Replies 5
Peter L
What type of interface are you looking at?
This is an output from a router with 6.4.2 and here you have input/output packet per second and kbyte (rate). It has been looking the same in previously releases also.
TenGigE0/0/0/0 is up, line protocol is up
Encapsulation ARPA
Traffic Stats:(2 second rates)                                     Delta
  Input  Packets:                2298903102                         2233
  Input  pps:                           898
  Input  Bytes:               2745217298817                      2534894
  Input  Kbps (rate):                  7423                       (  0%)
  Output Packets:                 370872787                          514
  Output pps:                           274
  Output Bytes:                 49181680080                        69706
  Output Kbps (rate):                   296                       (  0%)
Errors Stats:
  Input  Total:                           0                            0
  Input  CRC:                             0                            0
  Input  Frame:                           0                            0
  Input  Overrun:                         0                            0
  Output Total:                           0                            0
  Output Underrun:                        0                            0
Quit='q', Freeze='f', Thaw='t', Clear='c', Interface='i',
Next='n', Prev='p'
Brief='b', Detail='d', Protocol(IPv4/IPv6)='r'
Regards Peter
Hey Peter,
Thanks for checking, I am running 6.4.1 64bit on a 9901 platform and the command is not there for any type of interface...
RP/0/RSP0/CPU0:#monitor ?
  np         np packet monitoring(cisco-support)
  processes  Show process statistics
  threads    Show thread statistics
RP/0/RSP0/CPU0:#
It might be platform depending at this point.. or maybe the 64bit doesn't integrate that feature. On what device have you checked?
ADP
This is from a 9006 with 32bit ios-xr
RP/0/RSP0/CPU0:router#monitor ?
  controller  Display controller statistics
  interface   Display interface statistics and errors
RP/0/RSP0/CPU0:router#show version brief
Thu Sep 20 10:43:41.975 CET
Cisco IOS XR Software, Version 6.4.2[Default]
Copyright (c) 2018 by Cisco Systems, Inc.
Checked an ios-xrv 9000 router and the monitor interface command exist there also.
So most likely it's a 64 bit issue where this feature is missing. Seems strange that a hardware platform would miss the function.
/Peter
Bingo!
That was it, I have installed the asr9k-mgbl-x64-2.0.0.0-r641 rpm and the command is there now!
Many thanks,
ADP
