A99-4HG : tengig ports doesn't show up
allalamine
I'm trying to connect a A99-4HG-FLEX line card to ASR9910.
Only four 100G ports are available, anyone knows how to enable the remaining 40 tengig ports ?
RP/0/RSP0/CPU0:lab#sh int desc
Interface Status Protocol Description
Nu0 up up
Mg0/RSP0/CPU0/0 admin-down admin-down
Mg0/RSP1/CPU0/0 admin-down admin-down
Hu0/0/0/40 admin-down admin-down
Hu0/0/0/41 admin-down admin-down
Hu0/0/0/42 admin-down admin-down
Hu0/0/0/43 admin-down admin-down
BR,
allalamine
Thank you Sam,
Does it support oversubscription ? can we use all ports even if it is limited to 400G ?
It says "Oversubscription will be supported on these line cards in a future release of IOS XR 6.2.x train.", but in the second link, port configurations shown don't seem to support it.
BR,
Apologies I should not have used the second link, while it shows how to carve out the interfaces it is more applicable to the 10ge/1ge cards, oversubscription on this card is not possible. You can use this command to find the possible port combinations "show controller np valid-port-groups all". The layout of the card is like in the attached image.
Sam
allalamine
Clear, many thanks Sam
