A9K-2X100GE-SE card works in configuration with A9K-RSP880-TR
dorianaism
Hello everyone,
can you help me on this?
Are the A9K-2X100GE-SE cards works in configuration with A9K-RSP880-TR without issues or not. SE is higher version, but I believe it would downgrade to TR if paired with TR RSP?
is that right?
tkarnani
A9K-RSP880-TR will work with A9K-2X100GE-SE
the -TR on the RSP will have a lower memory scale on the RSP. the fabric speed will be the same as the RSP880-SE
Thank you
