MVPN configuration
sachin30720041
Hello All,
ios4----(g1)CSR1(g2)---------(g2)CSR2(g1)--------------(gi0/0/0/1)XRv3(gi0/0/0/2)----------(gii0/0/0/2)XRV4(gi0/0/0/0)-----ios5
ios4 and ios5 are CE routers.
CSR1 and XRV4 are PE routers. CSR3 and XRV3 are P routers.
I have done MVPN configuration on PE and P router. VPNV4 routes are exchanged between ios4 and ios5. SSM(231.231.0.0/16) is configured on PE and P routers. On IOS5, 'show ip pim rp mapping' command show empty results. I am not sure what configuration am I missing ?
ios4
ip multicast-routing
ip pim bsr-candidate lo0
ip pim rp-candidate lo0
int gi0/1
ip address 100.10.40.4 255.255.255.0
ip pim sparse-mode
ip ospf 1 area 0
no sh
int lo0
ip address 4.4.4.4 255.255.255.255
ip pim sparse-mode
ip ospf 1 area 0
exit
router ospf 1
exit
CSR1
ip multicast-routing distributed
ip multicast-routing vrf vrf1 distributed
vrf def vrf1
rd 1:1
address-family ipv4 unicast
route-target import 4:4
route-target export 1:1
mdt default 231.231.0.10
mdt data 231.231.10.0 0.0.0.255
mdt auto-discovery pim
exit
ip access-list standard SSM
permit 231.231.0.0 0.0.255.255
exit
ip pim ssm range SSM
router ospf 1 vrf vrf1
redistribute bgp 14
exit
int gi1
vrf forwarding vrf1
ip address 100.10.40.1 255.255.255.0
ip pim sparse-mode
ip ospf 1 area 0
no sh
int gi2
ip address 100.10.20.1 255.255.255.0
ip pim sparse-mode
ip router isis 1
isis network point-to-point
no sh
int lo0
ip address 1.1.1.1 255.255.255.255
ip router isis 1
ip pim sparse-mode
exit
router isis 1
passive-interface lo0
advertise passive-only
net 49.0001.1111.1111.1111.00
is-type level-2
metric-style wide
mpls ldp autoconfig
exit
router bgp 14
neighbor 4.4.4.4 remote-as 14
neighbor 4.4.4.4 update-source lo0
address-family ipv4 mvpn
neighbor 4.4.4.4 activate
exit
address-family vpnv4 unicast
exit
address-family ipv4 vrf vrf1
redistribute ospf 1
exit
exit
CSR2
exit
int gi2
ip address 100.10.20.2 255.255.255.0
ip router isis 1
ip pim sparse-mode
no sh
int gi1
ip address 100.20.30.2 255.255.255.0
ip router isis 1
ip pim sparse-mode
exit
int lo0
ip address 2.2.2.2 255.255.255.255
ip router isis 1
ip pim sparse-mode
exit
router isis 1
net 49.0001.2222.2222.2222.00
is-type level-2
metric-style wide
mpls ldp autoconfig
exit
XRV3
mpls ldp
exit
int gi0/0/0/1
ipv4 address 100.20.30.3 255.255.255.0
no sh
int gi0/0/0/2
ipv4 address 100.30.40.3 255.255.255.0
no sh
int lo0
ipv4 address 3.3.3.3 255.255.255.255
exit
ipv4 access-list SSM
permit ipv4 231.231.0.0 0.0.255.255 any
exit
router pim
address-family ipv4
ssm range SSM
int gi0/0/0/1
enable
int gi0/0/0/2
enable
int lo0
enable
exit
root
multicast-routing
address-family ipv4
int gi0/0/0/1
enable
int gi0/0/0/2
enable
int lo0
enable
exit
root
router isis 1
net 49.0001.3333.3333.3333.00
is-type level-2
metric-style wide
mpls ldp auto-config
exit
int gi0/0/0/1
point-to-point
exit
int gi0/0/0/2
point-to-point
exit
int lo0
passive
exit
root
XRV4
mpls ldp
exit
vrf vrf1
import route-target 1:1
export route-target 4:4
exit
root
int gi0/0/0/0
vrf vrf1
ipv4 address 100.40.50.4 255.255.255.0
no sh
int gi0/0/0/2
ipv4 address 100.30.40.4 255.255.255.0
no sh
int lo0
ipv4 address 4.4.4.4 255.255.255.255
exit
exit
route-policy pol1
set core-tree pim-default
exit
router pim
address-family ipv4
ssm range SSM
int gi0/0/0/2
enable
int lo0
enable
vrf vrf1
address-family ipv4
rpf topology route-policy pol1
int gi0/0/0/0
enable
exit
root
multicast-routing
address-family ipv4
int gi0/0/0/2
enable
int lo0
enable
exit
vrf vrf1
address-family ipv4
int gi0/0/0/0
enable
mdt default ipv4 231.231.0.10
mdt data 231.231.10.0/24
mdt source lo0
bgp auto-discovery pim
root
router isis 1
net 49.0001.4444.4444.4444.00
is-type level-2
metric-style wide
exit
int gi0/0/0/2
point-to-point
exit
int lo0
passive
exit
root
router ospf 1
vrf vrf1
redistribute bgp 14
area 0
int gi0/0/0/0
exit
root
router bgp 14
mvpn
exit
exit
exit
neighbor 1.1.1.1
remote-as 14
update-source lo0
exit
exit
vrf vrf1
rd 4:4
redistribute ospf 1
exit
exit
root
ios5
int gi0/0
ip address 100.40.50.5 255.255.255.0
ip ospf 1 area 0
ip pim sparse-mode
no sh
int lo0
ip address 5.5.5.5 255.255.255.255
ip pim sparse-mode
ip ospf 1 area 0
exit
router ospf 1
exit
Sachin
Harold Ritter
Hi @sachin30720041 ,
I think the fact that you are using the loopback address 4.4.4.4 on the BSR candidate RP (ios4) and on XRV4 might create a conflict. To validate that, could you run a "debug pim bsr" on XRV4. Don't forget to configure "logging console debugging" and commit for debug to work.
5 Replies 5
diefierr
Hi @sachin30720041
Is my understanding that this is a lab, and you learning how MVPN Profile 0 works.
you asking why "show ip pim rp mapping"  is empty, but i dont see any PIM RP configure anywhere.
i think you should go step by step.
1.- in CE <--> PEs, do we have pim neighbor? show ip pim vrf <vrf> interface / show ip pim vrf <vrf> neighbor
2.- in PE <--> P, do we have pim neighbor? show pim interface / show pim neighbor
3.- in PEs do you see PIM Neighbor the other PE via default MDT? show pim bgp / show bgp ipv4 mvpn summary / show pim vrf <vrf> neigbhro
you need to be sure all interface in the CORE are running PIM
you need to be sure all interface in the VRF are running PIM
look for BGP AFI to be up and advertising / learning mvpn routes
look for default MDT to be up.
Diego
Hi @diefierr ,
This is because SSM is configured in the core and BSR is used in the VRF. Either technique does not require explicit RP configuration.
My friend @Harold Ritter  if the underlay default MDT is not properly build no way IOS5 can see a thing.
So looking for pim rp before been sure if the CORE is working, if PIM Neigh are seen at VRF level between PEs is useless.
Always great to see you around.
Diego
Hi @diefierr ,
The default MDT should be just fine. It uses PIM SSM. There is absolutely no need for an RP in the core. The issue is not with the MDT here. The reason that ios5 does not receive the BSR messages is probably just that XRV4 is dropping them, as it sees a conflict with its own ip address. I am waiting for @sachin30720041 to confirm with the "debug pim bsr" output.
Good to hear from you too.
Harold Ritter
