A9K-800G-OPT-LIC
Peyman Zadmehr
I want to ask what is the exact usage of this license?
A9K-800G-OPT-LIC
Thank you
tkarnani
Hi Peyman
This license, A9K-800G-OPT- LIC Advanced Optical license is used if you want to enable G.709 and FEC for the 8-port 100GE line card
So If I connect the ports on the card to another 100GE switch with a small distance(Two racks away) I don't need this license.
Right?
Hi Peyman,
G709 feature is used when you have optical devices in between. if you do not enable this feature you will not need it.
Thank you
