A9K MOD80 Cannot Power up
HI Experts
I am meeting a strange issue of ASR9K MOD80. This MOD80 Card cannot power up, and always output log as below:
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-MOD80-SE state:MBI-RUNNING
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_KERNEL_DUMP_EVENT : Node 0/1/CPU0 indicates it is doing a kernel dump.
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-MOD80-SE state:IOS XR FAILURE
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-MOD80-SE state:BRINGDOWN
invmgr[249]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/1/CPU0, state: BRINGDOWN
canb-server[151]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/1/CPU0 , Power Cycle (0x05000000)
I have installed the Card to another A9K ( which version is same as the A9K) , and the MOD80 card can boot up and IOS XR RUN.
Did you have occur this issue ? Please help me to check it. many thks.
Attachment logging after MOD80 OIR collect..
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
2 Accepted Solutions
DUNG
I had the same problem.LC tested ok on another ASR9000. But it can't PWR UP any slot on this A9K chassis .I try redundancy switchover, and then LC can boot up.
shelfmgr[427]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/5/CPU0 A9K-MOD80-SE state:MBI-RUNNING
shelfmgr[427]: %PLATFORM-SHELFMGR-6-NODE_KERNEL_DUMP_EVENT : Node 0/6/CPU0 indicates it is doing a kernel dump.
shelfmgr[427]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/6/CPU0 A9K-MOD80-SE state:IOS XR FAILURE
shelfmgr[427]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/6/CPU0 A9K-MOD80-SE state:BRINGDOWN
invmgr[264]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/6/CPU0, state: BRINGDOWN
canb-server[158]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/6/CPU0 , Power Cycle (0x05000000)
ASR9010 with RSP440-TR
@DUNGThanks for the case you mentioned ,I also try to switchover the RSP ,and OIR line card ,then the issue have been resloved..
15 Replies 15
viweyam774
Are you Looking for Waikiki Health Portal? If you want to Access Waikiki Health Portal Official webpage then here you can see the official Waikiki Health Portal link. You can access all…  https://e-healthportal.org/
LaloRam
Hi @Rps-Cheers,
this LC is having kernel crashes
Open a TAC case to get these dumps decoded.
Eduardo
Yes, i have noticed this crash event and check it. I found there are some crashinfo ... i will try to get it.
I feel most strange that is the LC Insert to another A9K, it will run well. But it cannot PWR UP if i insert it to this A9K chassis any slot.
this could be related to the differences between both ASR 9000s. Can you please share the show platform and show install active summary of both ASR 9000?
Eduardo
  • Same Chassis
  • Same software version
  • Same install active (including Active Packages counts)
  • Same RSP (A9K-RSP440-TR)
  • Same MOD Card and MPA card .. ( A9K-MOD80-SE/A9K-MOD80-TR and A9K-MPA-4X10GE/A9K-MPA-20X1GE ..)
hi @Rps-Cheers
What about FPD version on both ASRs?
Eduardo,
Normal one:
                                        HW                       Current SW Upg/
Location     Card Type                Version Type Subtype Inst   Version   Dng?
0/RSP0/CPU0  A9K-RSP440-TR              1.0   lc   cbc     0      16.116    No
                                              lc   fpga1   0       0.10     No
                                              lc   fpga3   0       4.09     No
                                              lc   fpga2   0       1.06     Yes
                                              lc   rommon  0       0.73     No
0/0/CPU0     A9K-MOD80-TR               1.0   lc   cbc     0      20.118    No
                                              lc   fpga2   0       1.04     No
                                              lc   fpga4   0       1.05     No
                                              lc   rommon  0       3.02     Yes
0/2/CPU0     A9K-MOD80-SE               1.0   lc   cbc     0      20.118    No
                                              lc   fpga2   0       1.04     No
                                              lc   fpga4   0       1.05     No
                                              lc   rommon  0       3.03     Yes
<omit>
Abnormal one
                                        HW                       Current SW Upg/
                                              lc   fpga3   0       4.09     No
                                              lc   fpga2   0       1.06     Yes
                                              lc   fpga1   0       0.10     No
                                              lc   rommon  0       0.73     No
0/0/CPU0     A9K-MOD80-SE               1.0   lc   cbc     0      20.118    No
                                              lc   fpga2   0       1.04     No
                                              lc   fpga4   0       1.05     No
0/1/CPU0     A9K-MOD80-TR               1.0   lc   cbc     0      20.118    No
                                              lc   fpga4   0       1.05     No
                                              lc   fpga2   0       1.04     No
<omit>
FPDs seem to be ok in both setups, I recommend you to open a case with TAC to get these dumps decoded. It will be very useful to share this info with the TAC engineer.
Eduardo
well, i will. Many thxs.
DUNG
smilstea
So to answer you and the original poster (OP) there are many reasons why the card may not transition to XR RUN from MBI RUNNING, in short the main reason is for lack of an XR heartbeat message. That can be due to the control ethernet (CE) or also known as EOBC dropping the packet, XR VM not sending the heartbeat, etc etc. There was a bug way back that was super difficult to detect that it could be CSCuv65231. It affects all version before 5.3.3. It is caused by a slow leak in the mqueue process. Your best bet as the bug says is to connect to the console of the LC as its booting to see what is going on, you can do that on the asr9k with  attachcon.
RP/0/RSP1/CPU0:ASR9006-B#run attachCon 0/0/cpu0
Wed Aug 29 14:02:41.699 UTC
attachCon: Starting console session to node 0/0/cpu0
attachCon: To quit console session type 'detach'
Current Baud 115200
Setting Baud to 9600
ksh: e: not found
In the above example the card is already up and running in IOS-XR and this takes me to the ksh of the linecard.
Below is of a linecard starting to boot up normally.
Selecting ROMMON Image... B
DDR in Interleaved mode
POST 1 : PASSED : code 0 : DDR2 Memory
System Bootstrap, Version 1.03(20100211:014208) [ASR9K ROMMON],
Copyright (c) 1994-2010 by Cisco Systems, Inc.
Compiled Wed 10-Feb-10 17:42 by
CPU Reset Reason = 0x0005
PPC 8641D (partnum 0x0003), Revision 0.2, (Core Version 2.20136)
M8641 CLKIN: 66 Mhz
Core Clock: 1333 Mhz
MPX Clock: 533 Mhz
LBC Clock: 33 Mhz
Daughter Board Present: yes
Daughter Board ID: 7
Memory Option: 1
Board Type: 40221
POST 3 : PASSED : code 0 : Slot ID/Board Type
Loading Field Programmable Devices:
FPGA 0-B PROGRAMMED : image: 0xfd800028 - 0xfe1dbb28, et: 480ms
FPGA 1-B PROGRAMMED : image: 0xfd800028 - 0xfe1dbb28, et: 930ms
FPGA 2-B PROGRAMMED : image: 0xc0300028 - 0xc039f270, et: 29ms
Main Board: 0x40221, rev 0x3
PLD: 1.2
Bridge0: 1.2
Bridge1: 1.2
CBC: 6.2
Daughter Board: 0x7, rev 0x2, bom 0x2
DB Main PLD: 1.3
DB PLD: 0.8
IO FPGA: 0.11
PCI-E1: Ready as Root Complex
PCI-E2: Ready as Root Complex
ASR9K (8641D PPC) platform with 4096 Mb of main memory
CARD_SLOT_NUMBER: 2
CPU_INSTANCE: 1
MBI Validation starts ...
tsec_init_hw: configuring TSEC (port 1) for: 1GB, Full Duplex
tsec_init_interface: hardware initialization completed
Interface link changed state to UP.
Interface link state up.
MBI validation sending request.
HIT CTRL-C to abort
mbi_val_process_packet: received repsonse
Remote image to boot : tftp:/disk0/asr9k-os-mbi-4.2.1/lc/mbiasr9k-lc.vm
IP_ADDRESS: 127.0.1.2
IP_SUBNET_MASK: 255.255.0.0
DEFAULT_GATEWAY: 127.0.1.1
TFTP_SERVER: 127.0.1.1
TFTP_FILE: /disk0/asr9k-os-mbi-4.2.1/lc/mbiasr9k-lc.vm
Performing tftpdnld
Sam
Hi @smilstea
Our device is running 6.2.3.I want to know what it is LC HW problem or software bug.It doesn't hit bug CSCuv65231.Thanks!
RP/0/RSP1/CPU0:ASR9010#run attachCon 0/7/CPU0
Sat Aug 20 14:56:26.275 GMT
attachCon: Starting console session to node 0/7/CPU0
attachCon: WARNING - Type only 'detach' in the shell. Do not combine other keys.
Current Baud 115200
;C?System Bootstrap, Version 3.3(20150930:043930) [ASR9K ROMMON],
Copyright (c) 1994-2015 by Cisco Systems, Inc.
Compiled Wed 30-Sep-15 10:09 by vgothe
Starting Initialization of FMAN0
Loading ucode for FMAN0, size: 6992, ver: 101.08.00
Starting Initialization of FMAN1
Loading ucode for FMAN1, size: 6992, ver: 101.08.00
Initializing CPU serdes for rev2...
Serdes Protocol: 0xE
Internal Board type detected: 0x3
Initializing Zarlink(25M mode)...
Initializing MB ASICs...
Initializing Sacramento...
Initializing GIGE SW...
Initializing DB ASICs...
PPC P40X0 (partnum 0x8023), Revision 02.00, (Core Version 02.00)
Sys Clock: 100 Mhz
Core Clock: 1500 Mhz
Plat Clock: 800 Mhz
LBC Clock: 25 Mhz
MEM Clock: 1300 Mhz
Board Type: 0x2a0254
Memory Option: 0x3
CPU Board => Rev: 0x7
CPU PLD: 01.05.00
CBC: 20.118
Secondary Board => Rev: 0x3
DB PLD: 01.04 ()
PCI-E1: is enabled
PCI-E2: is enabled
PCI-E3: is enabled
Applying IDT PCIE SW Errata1 WA
ASR9K (P40X0 PPC) platform with 8192 Mb of main memory
CARD_SLOT_NUMBER: 9
CPU_INSTANCE: 1
dtsec_init_hw: configuring DTSEC (port for: 1GB, Full Duplex
HIT CTRL-C to abort
mbi_val_process_packet: received repsonse (rack 0)
Remote image to boot : tftp:/disk0/asr9k-os-mbi-6.2.3.CSCvg74808-1.0.0/lc/mbiasr9k-lc.vm
IP_ADDRESS: 127.0.1.9
DEFAULT_GATEWAY: 127.0.1.5
TFTP_SERVER: 127.0.1.5
TFTP_FILE: /disk0/asr9k-os-mbi-6.2.3.CSCvg74808-1.0.0/lc/mbiasr9k-lc.vm
Performing tftpdnld
tftp_process_packet: received OACK.
tftp_process_packet: Change blksize to 1400.
Receiving /disk0/asr9k-os-mbi-6.2.3.CSCvg74808-1.0.0/lc/mbiasr9k-lc.vm from 127.0.1.5 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
tftp_process_packet: last packet, block=15556, size=1284.
File reception completed.
Image size=21778284, TFTP download size=21778284
program load complete, entry point: 0x2037dc, size: 0x14c406c
Config = SMP, Running = SMP
Board type: 0x002a0254
Card Capability = 0x00000014
BSP: Board type :XMEN-LC
tracelogger: starting tracing in background ring mode
tracelogger running with args: -startring -F 1 -F 2
 Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS XR Software for the Cisco XR ASR9K, Version 6.2.3
Copyright (c) 2019 by Cisco Systems, Inc.
# Aug 20 06:57:52.652: Install Setup: Preparing devices:
Aug 20 06:57:52.654: Install Setup: Complete
Aug 20 06:57:52.654: Install Setup: Starting package and meta-data sync
Aug 20 06:57:52.657: Install Setup: Syncing package 'asr9k-adv-video-supp-6.2.3':
Aug 20 06:57:52.814: Install Setup: Complete
Aug 20 06:57:52.815: Install Setup: Syncing package 'asr9k-base-6.2.3':
Aug 20 06:58:04.275: Install Setup: Complete
Aug 20 06:58:04.286: Install Setup: Syncing package 'asr9k-base-6.2.3.CSCvi90822-1.0.0':
Aug 20 06:58:04.606: Install Setup: Complete
Aug 20 06:58:04.606: Install Setup: Syncing package 'asr9k-base-6.2.3.CSCvj43752-1.0.0':
Aug 20 06:58:04.926: Install Setup: Complete
Aug 20 06:58:04.926: Install Setup: Syncing package 'asr9k-base-6.2.3.CSCvj55087-1.0.0':
Aug 20 06:58:04.984: Install Setup: Complete
Aug 20 06:58:04.984: Install Setup: Syncing package 'asr9k-base-6.2.3.CSCvn41916-1.0.0':
Aug 20 06:58:05.551: Install Setup: Complete
Aug 20 06:58:05.552: Install Setup: Syncing package 'asr9k-base-6.2.3.CSCvn51108-1.0.0':
Aug 20 06:58:08.688: Install Setup: Complete
Aug 20 06:58:08.692: Install Setup: Syncing package 'asr9k-bng-6.2.3':
Aug 20 06:58:08.777: Install Setup: Complete
Aug 20 06:58:08.778: Install Setup: Syncing package 'asr9k-ce-6.2.3':
Aug 20 06:58:08.929: Install Setup: Complete
Aug 20 06:58:08.930: Install Setup: Syncing package 'asr9k-cpp-6.2.3':
Aug 20 06:58:09.093: Install Setup: Complete
Aug 20 06:58:09.094: Install Setup: Syncing package 'asr9k-cpp-6.2.3.CSCvo06271-1.0.0':
Aug 20 06:58:09.152: Install Setup: Complete
Aug 20 06:58:09.153: Install Setup: Syncing package 'asr9k-diags-supp-6.2.3':
PID 40977: _dl_abort. libinst.dll:dllmgr: Dll not in proper format libinst.dll [/pkg/lib/libinst.dll] err_str [No such file or directory]
Process 49192 (instsetup) terminated SIGSEGV code=1 fltno=11 ip=4a440b68 ref=00000001 bdslot=1
Aug 20 06:58:12.568: Install Setup: Preparing devices:
Aug 20 06:58:12.571: Install Setup: Complete
Aug 20 06:58:12.571: Install Setup: Starting package and meta-data sync
Aug 20 06:58:13.269: Install Setup: Syncing package 'asr9k-diags-supp-6.2.3':
PID 94225: _dl_abort. libinst.dll:dllmgr: Dll not in proper format libinst.dll [/pkg/lib/libinst.dll] err_str [No such file or directory]
Process 90152 (instsetup) terminated SIGSEGV code=1 fltno=11 ip=4a440b68 ref=00000001
Aug 20 06:58:17.038: Install Setup: Preparing devices:
Aug 20 06:58:17.040: Install Setup: Complete
Aug 20 06:58:17.040: Install Setup: Starting package and meta-data sync
Aug 20 06:58:17.741: Install Setup: Syncing package 'asr9k-diags-supp-6.2.3':
PID 102417: _dl_abort. libinst.dll:dllmgr: Dll not in proper format libinst.dll [/pkg/lib/libinst.dll] err_str [No such file or directory]
Process 98344 (instsetup) terminated SIGSEGV code=1 fltno=11 ip=4a440b68 ref=00000001
Aug 20 06:58:21.477: Install Setup: Preparing devices:
Aug 20 06:58:21.480: Install Setup: Complete
Aug 20 06:58:21.480: Install Setup: Starting package and meta-data sync
KD: Copied LC7.220820-065546.crashinfo.by.init to /lcdisk0:/dumper
Aug 20 06:58:22.351: Install Setup: Syncing package 'asr9k-diags-supp-6.2.3':
KD: Copied LC7.220820-065546.pcds to /lcdisk0:/dumper
PID 110609: _dl_abort. libinst.dll:dllmgr: Dll not in proper format libinst.dll [/pkg/lib/libinst.dll] err_str [No such file or directory]
Process 106536 (instsetup) terminated SIGSEGV code=1 fltno=11 ip=4a440b68 ref=00000001
Aug 20 06:58:25.953: Install Setup: Preparing devices:
Aug 20 06:58:25.956: Install Setup: Complete
Aug 20 06:58:25.956: Install Setup: Starting package and meta-data sync
Aug 20 06:58:26.654: Install Setup: Syncing package 'asr9k-diags-supp-6.2.3':
PID 139281: _dl_abort. libinst.dll:dllmgr: Dll not in proper format libinst.dll [/pkg/lib/libinst.dll] err_str [No such file or directory]
Process 1352% Media type /nvram: doesn't exist in this node!
% Media type /configflash: doesn't exist in this node!
07 (instsetup) terminated SISuccessed to rename debug file, 2, src: /bootflash:/sysmgr.log.timeout.Z, target: /bootflash:/prev.sysmgr.log.timeout.Z
Aug 20 06:58:30.491 : SYSMGR_LITE: Saving init logs in /bootflash:/sysmgr.log.timeout.Z ...
GSEGV code=1 fltno=11 ip=4a440b68 ref=0000Aug 20 06:58:30.633 : SYSMGR_LITE: INIT: respawn 'instsetup' disabled, exit_code 11, INIT_MAX_SPAWN reached
0001
Aug 20 06:58:31.003 : SYSMGR_LITE: Saving init logs in /bootflash:/sysmgr.log.timeout.Z ...
Aug 20 06:58:31.143 : SYSMGR_LITE: INIT: respawn 'dumper' disabled, exit_code 6, INIT_MAX_SPAWN reached
reboot internal : cause code 671088647 cause INIT: respawn 'instsetup' disabled, exit_code 11, INIT_MAX_SPAWN reached
reboot internal : cause code 671088647 cause INIT: respawn 'dumper' disabled, exit_code 6, INIT_MAX_SPAWN reached
reboot_internal timeout 30 is graceful no
reboWoriting crashinfo
Active processes:
proc/boot/procnto-booke-smp-instr Thread ID 0 on cpu 0
Active processes:
proc/boot/procnto-booke-smp-instr Thread ID 1 on cpu 1
Active processes:
asr9k-os-6.2.3.CSCvg74808-1.0.0/0x30207/bin/init Thread ID 5 on cpu 2
Active processes:
proc/boot/procnto-booke-smp-instr Thread ID 10 on cpu 3
? ?;C?System Bootstrap, Version 3.3(20150930:043930) [ASR9K ROMMON],
I guess it's a software issue. As your meaning, it will recovery after RSP switchover, just as RSP reload..
smilstea
Your logs are indicating corruption in the package diags. That is why the package fails to sync to the LC and the LC reboots.
Corruption can happen for a number of reasons, you can verify with an 'install verify'. You can only do a repair if the corruption exists on the standby, we don't want to mess with the active running packages on the active rsp for obvious reasons so the system doesn't allow to fix corruption on the active rsp. Even if you try a repair it might not work and then the only solution is to turboboot the router.
Sam
