ar9k template problem
nethousebimltd
I am trying to create a template script, but it's not working. Where am I going wrong?
Template: create_l2if (if, vlan)
interface TenGigE $if.$vlan l2transport
encapsulation dot1q $vlan
rewrite ingress tag pop 2 symmetric
Apply-template create_l2if (0/0/0/28/0, 1234)
tkarnani
there seems to be an issue with the pop 2 symmetric, you will need to match on 2 if you plan to pop 2
for example
encapsulation dot1q 100 second-dot1q 200
otherwise you would use pop 1 symmetric
no,
this is ok :
interface TenGigE0/5/0/8.307 l2transport
 encapsulation dot1q 100 second-dot1q 307
when i try to create using template feature with variable is not creating interface
