ASR 9000 NP FAILED_RX_PATH
oscar.garcia88
Hi everyone,
I have problem with below log and suddenly the NP stop forwarding packet please advise the solution and how to tshoot
Regards.
tkarnani
Hi Oscar,
these errors are due to the diagnostic check described here
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116727-troubleshoot-punt-00.html
essentially the RP is sending a diagnostic packet to the NPU and since its not being returned it sets this alarm
this can mean the NPU is faulty or has a transient fault.
we would recommend re-loading the LC to see if it recovers. if it does not you may have to replace it with a spare
thanks
Thanks Karnani,
I will try it and get back to you. Do you know what can be triggered because of this alarm?
Regards.
