ASR 9001 / A9K-MPA-4X10GE IS DISABLED
carlos0034
  I have a module A9K-MPA-4X10GE in slot 0/0/0 which the Oper State : DISABLED anyone has been there to help me to figured this out.
any help will be appreciated.
Please see below my output.
  RP/0/RSP0/CPU0:us-fmt-core2.rtr#show platform
Tue May 24 12:37:44.662 UTC
Node Type State Config State
0/RSP0/CPU0 ASR9001-RP(Active) IOS XR        RUN PWR,NSHUT,MON
0/0/CPU0 ASR9001-LC IOS XR                             RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-4X10GE                              DISABLED PWR,NSHUT,MON
0/0/1 A9K-MPA-20X1GE                               OK PWR,NSHUT,MON
RP/0/RSP0/CPU0:us-fmt-core2.rtr#show platform summary location all
Tue May 24 12:41:50.019 UTC
Platform Node : 0/RSP0/CPU0 (slot 0)
PID : ASR9001-RP
Card Type : ASR 9001, Route Switch Processor with 8GB memory
VID/SN : V01 / FOC1814NJ4J
Oper State : IOS XR RUN
Last Reset : User Initiated reload Process: reload
: Tue May 17 15:36:43 2016
Configuration : Power is enabled
Bootup enabled.
Monitoring enabled
Rommon Ver : Version 2.03(20131022:110718)
IOS SW Ver : 5.3.1
Main Power : Power state Enabled. Estimate power 50 Watts of power requi red.
Faults : N/A
Platform Node : 0/0/CPU0 (slot 2)
PID : ASR9001-LC
Card Type : ASR 9001, Modular Line Card
VID/SN : V01 / FOC1814NJF3
Last Reset : Reloading managed node Process: insthelper
: Tue Jan 5 15:55:29 2016
Bootup enabled.
Monitoring enabled
Rommon Ver : Version 2.03(20131022:111059)
IOS SW Ver : 5.3.1
Main Power : Power state Enabled. Estimate power 330 Watts of power requ ired.
Faults : N/A
Platform Node : 0/0/0 (slot 2, bay 0)
PID :
Card Type : ASR 9000 4-port 10GE Modular Port Adapter
VID/SN : /
Last Reset : Mon May 23 08:49:21 2016
Up Time : 00:00:00
Bootup enabled
Monitoring enabled
FPD SW Rev(s) :
Platform Node : 0/0/1 (slot 2, bay 1)
PID : A9K-MPA-20X1GE
Card Type : ASR 9000 20-port 1GE Modular Port Adapter
RP/0/RSP0/CPU0:us-fmt-core2.rtr#show diag
Tue May 24 12:51:50.677 UTC
NODE module 0/RSP0/CPU0 ASR 9001, Route Switch Processor with 8GB memory
MAIN: board type 0x100401
S/N: FOC1814NJ4J
Top Assy. Number: 00-0000-00
PID: ASR9001-RP
HwRev (UDI_VID): V01
Chip HwRev: V1.0
New Deviation Number: 0
CLEI:
Board State : IOS XR RUN
PLD: Motherboard: N/A, Processor version: 0x8023 (rev: 2.0), Power: N/A
MONLIB: QNXFFS Monlib Version 3.3
ROMMON: Version 2.03(20131022:110718) [ASR9K ROMMON]
Board FPGA/CPLD/ASIC Hardware Revision:
IntCtrl : V0.0
USB0 : V17.0
ClkCtrl : V0.0
CPUCtrl : V0.0
MLANSwitch : V0.0
EOBCSwitch : V2.0
LIU : V0.0
YDTI : V0.0
PHY : V0.0
CBC (active partition) : v22.114
CBC (inactive partition) : v22.114
NODE module 0/0/CPU0 ASR 9001, Modular Line Card
MAIN: board type 0xf10402
S/N: FOC1814NJF3
PCA: 73-14312-05
PID: ASR9001-LC
Chip HwRev: V1.0
CLEI:
ROMMON: Version 2.03(20131022:111059) [ASR9K ROMMON]
NP0 : V4.194
NP1 : V4.194
FIA0 : V0.2
FIA1 : V0.2
X-Bar : V1.5
CPUCtrl : V1.18
FabArbiter : V0.0
PortCtrl : V1.18
PHYCtrl : V1.18
ClkCtrl : V1.18
PHY0 : V0.4(HwRev) V8.0(FwRev) V8.0(SwRev)
DBCtrl : V2.10
Power Sequencer0 : V0.0
Power Sequencer1 : V0.0
Power Sequencer2 : V0.0
Modular Linecard Daughter board : V1.0
CBC (active partition) : v23.114
CBC (inactive partition) : v23.114
SPA 0/0/0 : ASR 9000 4-port 10GE Modular Port Adapter
MAIN: board type 0237
68-3730-08 rev A0
dev 143395
S/N FOC1818NFHB
PCA: 73-13150-08 rev N/A
PID: A9K-MPA-4X10GE
VID: V05
CLEI: IPUIBRDRAE
Board State : DISABLED
FPD Software Revision:
SPA 0/0/1 : ASR 9000 20-port 1GE Modular Port Adapter
MAIN: board type 0235
68-3959-06 rev A0
dev 139030
S/N FOC1801N6D2
PCA: 73-13152-04 rev N/A
PID: A9K-MPA-20X1GE
VID: V02
CLEI: IPUIBVTRAA
Board State : OK
smilstea
In addition to what Aaron said, what actions were taken to get into this state?
IE did you OIR an MPA, issue a reload command, etc etc?
Sam
9 Replies 9
AARON WEINTRAUB
if you take out and re-insert the MPA, what syslogs appear?
I'm not sure if in order to make the line card works do I need to upgrade the license?
 I  power-off the module and re-insert same results.
 Thanks of both of you guys.
 Best regards.
here is the syslog.
RP/0/RSP0/CPU0:us-fmt-core2.rtr#show logging
Tue May 24 12:44:47.523 UTC
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
    Console logging: level warnings, 80 messages logged
    Monitor logging: level debugging, 0 messages logged
    Trap logging: level informational, 0 messages logged
    Buffer logging: level debugging, 427 messages logged
Log Buffer (307200 bytes):
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:        CN=Cisco Root CA 2048,O=Cisco Systems
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Va        lidity Start : 20:17:12 UTC Fri May 14 2004
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Va        lidity End   : 20:25:42 UTC Mon May 14 2029
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   SH        A1 Fingerprint:
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:        DE990CED99E0431F60EDC3937E7CD5BF0ED9E5FA
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Se        rial Number  : 2E:D2:0E:73:47:D3:33:83:4B:4F:DD:0D:D7:B6:96:7E
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Su        bject:
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:        CN=Cisco Root CA M1,O=Cisco
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Is        sued By      :
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Va        lidity Start : 21:50:24 UTC Tue Nov 18 2008   Validity End   : 21:59:46 UTC Fri        Nov 18 2033   SHA1 Fingerprint:          45AD6BB499011BB4E84E84316A81C27D89EE5CE        7    Serial Number  : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B   Subject:        CN=DST Root CA X3,O=Digital Signature Trust Co.   Issued By      :        CN=DST Root CA X3,O=Digital Signature Trust Co.   Validity Start : 21:12:19 UTC        Sat Sep 30 2000   Validity End
 : 14:01:15 UTC Thu Sep 30 2021   SHA1 Fingerprint:
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914: 0:24        UTC Tue Nov 18 2008
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Va        lidity End   : 21:59:46 UTC Fri Nov 18 2033
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:        45AD6BB499011BB4E84E84316A81C27D89EE5CE7
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Se        rial Number  : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:        CN=DST Root CA X3,O=Digital Signature Trust Co.
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Va        lidity Start : 21:12:19 UTC Sat Sep 30 2000
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:   Va        lidity End   : 14:01:15 UTC Thu Sep 30 2021
RP/0/RSP0/CPU0:May 21 02:09:45.137 : syslog_dev[94]: cepki[161] PID-540914:        DAC9024F54D8F6DF94935FB1732638CA6AD77C13
RP/0/RSP0/CPU0:May 21 02:09:45.138 : syslog_dev[94]: cepki[161] PID-540914:
RP/0/RSP0/CPU0:May 21 02:09:45.240 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is not ready. Reason: [V4 Subscriber infra proces        s(es) is unavailable].
RP/0/RSP0/CPU0:May 21 02:09:45.240 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is not ready. Reason: [V6 Subscriber infra proces        s(es) is unavailable].
RP/0/RSP0/CPU0:May 21 02:09:45.540 : ipsec_mp[253]: %SECURITY-IMP-6-PROC_READY :        Process ipsec_mp is ready
RP/0/RSP0/CPU0:May 21 02:09:47.353 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is ready. Reason: [V4 Subscriber infra process(es        ) is available].
RP/0/RSP0/CPU0:May 21 02:09:47.353 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is ready. Reason: [V6 Subscriber infra process(es        ) is available].
RP/0/RSP0/CPU0:May 21 02:09:52.348 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is not ready. Reason: [V4 Subscriber infra proces        s(es) is unavailable].
RP/0/RSP0/CPU0:May 21 02:09:52.992 : ipsub_ma[287]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is not ready. Reason: [V4 Subscriber infra proces        s(es) is unavailable].
RP/0/RSP0/CPU0:May 21 02:09:53.228 : ipsub_ma[287]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is not ready. Reason: [V6 Subscriber infra proces        s(es) is unavailable].
RP/0/RSP0/CPU0:May 21 02:09:53.229 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is not ready. Reason: [V6 Subscriber infra proces        s(es) is unavailable].
RP/0/RSP0/CPU0:May 21 02:10:11.919 : pim6[1181]: %ROUTING-IPV4_PIM-6-HA_INFO : N        SR ready: Transitioning to ready state
RP/0/RSP0/CPU0:May 21 02:10:12.141 : pim[1180]: %ROUTING-IPV4_PIM-6-HA_INFO : NS        R ready: Transitioning to ready state
RP/0/RSP0/CPU0:May 21 02:10:13.689 : ipsub_ma[287]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is ready. Reason: [V4 Subscriber infra process(es        ) is available].
RP/0/RSP0/CPU0:May 21 02:10:13.690 : ipsub_ma[287]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is ready. Reason: [V6 Subscriber infra process(es        ) is available].
RP/0/RSP0/CPU0:May 21 02:10:13.690 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is ready. Reason: [V4 Subscriber infra process(es        ) is available].
RP/0/RSP0/CPU0:May 21 02:10:13.690 : pppoe_ma[378]: %SUBSCRIBER-SUB_UTIL-5-SESSI        ON_THROTTLE : Subscriber Infra is ready. Reason: [V6 Subscriber infra process(es        ) is available].
RP/0/RSP0/CPU0:May 21 02:10:13.908 : placed[368]: LR-PLANE-READY DECLARATION
RP/0/RSP0/CPU0:May 21 02:10:19.113 : dsc[188]: %PLATFORM-DSC_CTRL-6-RACK_STATE :        Rack 1 is now Down
RP/0/RSP0/CPU0:May 21 02:10:19.118 : gsp[242]: gsp_rack_down_handler: for node:0        x1
RP/0/RSP0/CPU0:May 21 02:10:39.428 : cfgmgr-rp[164]: cfgmgr_spm_partition_depend        ency_add_2029: duplicate partition 'sh_lc'
RP/0/RSP0/CPU0:May 21 02:10:39.429 : cfgmgr-rp[164]: cfgmgr_spm_partition_depend        ency_add_2029: duplicate partition 'sh_lc'
RP/0/RSP0/CPU0:May 21 02:10:41.053 : ifmgr[248]: %PKT_INFRA-LINK-5-CHANGED : Int        erface MgmtEth0/RSP0/CPU0/0, changed state to Administratively Down
RP/0/RSP0/CPU0:May 21 02:10:41.056 : ifmgr[248]: %PKT_INFRA-LINK-5-CHANGED : Int        erface MgmtEth0/RSP0/CPU0/1, changed state to Administratively Down
RP/0/RSP0/CPU0:May 21 02:10:41.060 : cfgmgr-rp[164]: %MGBL-CONFIG-6-OIR_RESTORE        : Configuration for node '0/RSP0/0' has been restored.
RP/0/RSP0/CPU0:May 21 02:10:54.229 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/CPU0 ASR9001-LC state:MBI-RUNNING
LC/0/0/CPU0:13: init[65540]: %OS-INIT-7-MBI_STARTED : total time 5.610 seconds
LC/0/0/CPU0:May 21 02:11:48.660 : sysmgr[91]: %OS-SYSMGR-5-NOTICE : Card is COLD        started
LC/0/0/CPU0:May 21 02:11:49.261 : init[65540]: %OS-INIT-7-INSTALL_READY : total        time 61.572 seconds
LC/0/0/CPU0:May 21 02:11:49.930 : sysmgr[364]: %OS-SYSMGR-6-INFO : Backup system        manager is ready
LC/0/0/CPU0:May 21 02:11:58.406 : prm_server_ty[313]: %PLATFORM-QOSHAL-6-FLOW_QO        S_CONFIG : Flow Aware QoS is disabled. max flow count set to 0
LC/0/0/CPU0:May 21 02:11:58.431 : prm_server_ty[313]: %PLATFORM-QOSHAL-6-QOS_MOD        E_CHANGE : Line-card QoS mode set to child-shaping-enabled.
LC/0/0/CPU0:May 21 02:11:58.431 : prm_server_ty[313]: %PLATFORM-QOSHAL-6-QOS_MOD        E_CHANGE : Line-card QoS mode set to lowburst-disabled.
LC/0/0/CPU0:May 21 02:11:58.431 : prm_server_ty[313]: %PLATFORM-QOSHAL-6-QOS_MOD        E_CHANGE : Line-card QoS mode set to l4-wred-buffer-mode-disabled.
LC/0/0/CPU0:May 21 02:11:58.431 : prm_server_ty[313]: %PLATFORM-QOSHAL-6-QOS_MOD        E_CHANGE : Line-card QoS mode set to per-priority-limit-disabled.
RP/0/RSP0/CPU0:May 21 02:12:03.301 : invmgr[257]: %PLATFORM-INV-6-IF_OIRIN : xFP        OIR: 0/0/2 port_num: 0 is inserted, state: 1
RP/0/RSP0/CPU0:May 21 02:12:04.900 : invmgr[257]: %PLATFORM-INV-6-IF_OIRIN : xFP        OIR: 0/0/2 port_num: 1 is inserted, state: 1
RP/0/RSP0/CPU0:May 21 02:12:06.500 : invmgr[257]: %PLATFORM-INV-6-IF_OIRIN : xFP        OIR: 0/0/2 port_num: 2 is inserted, state: 1
RP/0/RSP0/CPU0:May 21 02:12:08.100 : invmgr[257]: %PLATFORM-INV-6-IF_OIRIN : xFP        OIR: 0/0/2 port_num: 3 is inserted, state: 1
RP/0/RSP0/CPU0:May 21 02:12:11.825 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/0 UNKNOWN state:UNPOWERED
RP/0/RSP0/CPU0:May 21 02:12:11.837 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/1 UNKNOWN state:UNPOWERED
RP/0/RSP0/CPU0:May 21 02:12:21.703 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/1 A9K-MPA-20X1GE state:POWER UP
RP/0/RSP0/CPU0:May 21 02:12:21.712 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/0 A9K-MPA-4X10GE state:POWER UP
LC/0/0/CPU0:May 21 02:12:22.586 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 1 type A9K-MPA-20X1GE Initing
LC/0/0/CPU0:May 21 02:12:22.708 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 0 type A9K-MPA-4x10GE Initing
RP/0/RSP0/CPU0:May 21 02:12:23.623 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/1 A9K-MPA-20X1GE state:INITIALIZED
RP/0/RSP0/CPU0:May 21 02:12:24.936 : invmgr[257]: %PLATFORM-INV-6-IF_OIRIN : xFP        OIR: 0/0/1 port_num: 7 is inserted, state: 1
RP/0/RSP0/CPU0:May 21 02:12:26.540 : invmgr[257]: %PLATFORM-INV-6-IF_OIRIN : xFP        OIR: 0/0/1 port_num: 18 is inserted, state: 1
LC/0/0/CPU0:May 21 02:12:27.497 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        plugin_init failed in init_callback_action
RP/0/RSP0/CPU0:May 21 02:12:27.511 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: FAILED
RP/0/RSP0/CPU0:May 21 02:12:27.516 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/0 A9K-MPA-4X10GE state:IN-RESET
RP/0/RSP0/CPU0:May 21 02:12:28.514 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: UNPOWERED
LC/0/0/CPU0:May 21 02:12:29.819 : lda_server[65]: %PLATFORM-UPGRADE_FPD-4-DOWN_R        EV : fpga3 instance 1 is down-rev (V0.08), upgrade to (V1.00). Use the "upgrade        hw-module fpd" CLI in admin mode.
LC/0/0/CPU0:May 21 02:12:33.429 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 0 type A9K-MPA-4x10GE Initing
LC/0/0/CPU0:May 21 02:12:34.119 : rommon_fpd_agent[328]: %PLATFORM-UPGRADE_FPD-4        -DOWN_REV : rommon instance 0 is down-rev (V2.03), upgrade to (V2.04). Use the "        upgrade hw-module fpd" CLI in admin mode.
LC/0/0/CPU0:May 21 02:12:38.220 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        plugin_init failed in init_callback_action
RP/0/RSP0/CPU0:May 21 02:12:38.234 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: FAILED
RP/0/RSP0/CPU0:May 21 02:12:39.237 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: UNPOWERED
LC/0/0/CPU0:May 21 02:12:44.145 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 0 type A9K-MPA-4x10GE Initing
LC/0/0/CPU0:May 21 02:12:47.764 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Set|envmon_lc[151635]|0x1029028|Port_2/00
LC/0/0/CPU0:May 21 02:12:47.770 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Set|envmon_lc[151635]|0x1029029|Port_2/01
LC/0/0/CPU0:May 21 02:12:47.770 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Set|envmon_lc[151635]|0x102902a|Port_2/02
LC/0/0/CPU0:May 21 02:12:47.770 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Set|envmon_lc[151635]|0x102902b|Port_2/03
LC/0/0/CPU0:May 21 02:12:48.945 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        plugin_init failed in init_callback_action
RP/0/RSP0/CPU0:May 21 02:12:48.958 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: FAILED
RP/0/RSP0/CPU0:May 21 02:12:49.964 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: UNPOWERED
LC/0/0/CPU0:May 21 02:12:54.852 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 0 type A9K-MPA-4x10GE Initing
LC/0/0/CPU0:May 21 02:12:59.700 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        plugin_init failed in init_callback_action
RP/0/RSP0/CPU0:May 21 02:12:59.714 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: FAILED
RP/0/RSP0/CPU0:May 21 02:13:00.718 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: UNPOWERED
LC/0/0/CPU0:May 21 02:13:05.614 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 0 type A9K-MPA-4x10GE Initing
RP/0/RSP0/CPU0:May 21 02:13:07.386 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/1 A9K-MPA-20X1GE state:OK
RP/0/RSP0/CPU0:May 21 02:13:07.395 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/1, state: OK
RP/0/RSP0/CPU0:May 21 02:13:07.400 : invmgr[257]: %PLATFORM-INV-6-OIRIN : OIR: N        ode 0/0/1 Sn: FOC1801N6D2 inserted
LC/0/0/CPU0:May 21 02:13:10.406 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        plugin_init failed in init_callback_action
RP/0/RSP0/CPU0:May 21 02:13:10.420 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: FAILED
RP/0/RSP0/CPU0:May 21 02:13:11.424 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: UNPOWERED
LC/0/0/CPU0:May 21 02:13:16.319 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 0 type A9K-MPA-4x10GE Initing
RP/0/RSP0/CPU0:May 21 02:13:20.652 : shelfmgr[412]: %PLATFORM-SHELFMGR-6-NODE_ST        ATE_CHANGE : 0/0/CPU0 ASR9001-LC state:IOS XR RUN
RP/0/RSP0/CPU0:May 21 02:13:20.661 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/CPU0, state: IOS XR RUN
LC/0/0/CPU0:May 21 02:13:21.107 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        plugin_init failed in init_callback_action
RP/0/RSP0/CPU0:May 21 02:13:21.120 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: FAILED
RP/0/RSP0/CPU0:May 21 02:13:22.124 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: UNPOWERED
LC/0/0/CPU0:May 21 02:13:25.017 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace TenGigE0/0/2/0, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.022 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace TenGigE0/0/2/1, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.022 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace TenGigE0/0/2/2, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.022 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace TenGigE0/0/2/3, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.026 : cfgmgr-lc[139]: %MGBL-CONFIG-6-OIR_RESTORE : C        onfiguration for node '0/0/2' has been restored.
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/0, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/1, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/2, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/3, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/4, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/5, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/6, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/7, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/8, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.181 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/9, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/10, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/11, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/12, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/13, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/14, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/15, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/16, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/17, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/18, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:25.182 : ifmgr[212]: %PKT_INFRA-LINK-5-CHANGED : Interf        ace GigabitEthernet0/0/1/19, changed state to Administratively Down
LC/0/0/CPU0:May 21 02:13:27.016 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA i        n bay 0 type A9K-MPA-4x10GE Initing
LC/0/0/CPU0:May 21 02:13:31.793 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        plugin_init failed in init_callback_action
LC/0/0/CPU0:May 21 02:13:31.795 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        A SPA hardware or software error occurred, please contact technical support
RP/0/RSP0/CPU0:May 21 02:13:31.805 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: FAILED
RP/0/RSP0/CPU0:May 21 02:13:32.809 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: UNPOWERED
RP/0/RSP0/CPU0:May 21 02:13:35.864 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHA        NGE : Node: 0/0/0, state: DISABLED
LC/0/0/CPU0:May 21 02:14:00.210 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Clear|envmon_lc[151635]|0x1029028|Port_2/00
LC/0/0/CPU0:May 21 02:14:00.211 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Clear|envmon_lc[151635]|0x1029029|Port_2/01
LC/0/0/CPU0:May 21 02:14:00.212 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Clear|envmon_lc[151635]|0x102902a|Port_2/02
LC/0/0/CPU0:May 21 02:14:00.212 : pfm_node_lc[300]: %PLATFORM-SFP-2-LOW_RX_POWER        _ALARM : Clear|envmon_lc[151635]|0x102902b|Port_2/03
RP/0/RSP0/CPU0:May 21 04:02:50.583 : exec[65749]: %SECURITY-LOGIN-6-AUTHEN_SUCCE        SS : Successfully authenticated user 'cisco' from 'console' on 'con0_RSP0_CPU0'
RP/0/RSP0/CPU0:May 21 04:13:41.556 : exec[65749]: %SECURITY-LOGIN-6-CLOSE : User        'cisco' logged out
RP/0/RSP0/CPU0:May 21 07:22:14.632 : exec[65749]: %SECURITY-LOGIN-6-AUTHEN_SUCCE        SS : Successfully authenticated user 'cisco' from 'console' on 'con0_RSP0_CPU0'
RP/0/RSP0/CPU0:May 21 07:27:12.154 : logger[65775]: %OS-SYSLOG-6-LOG_INFO : Buff        er (307200 bytes):
RP/0/RSP0/CPU0:May 21 07:39:11.881 : exec[65749]: %SECURITY-LOGIN-6-CLOSE : User        'cisco' logged out
LDA server got an error after which the MPA goes into a failed state:
LC/0/0/CPU0:May 21 02:13:21.107 : lda_server[65]: %L2-SPA-5-OIR_ERROR : SPA (0):        &n! bsp;                                                          plugin_init failed in init_callback_action
I would recommend opening a TAC case to investigate the LDA server traces to see why the MPA failed.
This looks like it was a cold boot of the entire router so there really isn't a trigger, just the booting of the router.
Sam
smilstea
Sam
Hi all,
What was the conclusion to this question.
Is a license required in order to activate the ports on the A9K-MPA-4x10GE within the ASR-9001-S or not?
The post seem not to come to a definitive conclusion.
This post was about a 9001 not a 9001-S.
If you want to use the second bay on a 9001-S then yes you need a license.
Sam
Hi Sam,
Sure, I see.
Thanks for that.
Hello Sam,
So what was the solution here?
This never got resolved here, but there are a few bugs related to MPAs going down in a 9001. These come to mind:
CSCuq98778
CSCuo74055
If you have a 9001-S then one of the sub-slots is disabled until you have installed the license.
Sam
