ASR 9001 SFP+ ports compatibility
Jordi Benet
will the SFP+ ports on the 9001 chassis support a 1 Gbps SFP?
which one?
Thanks a lot.
J
smilstea
Hi Jordi,
The ports only do 10Gbps.
For 1Gbps you will need the 20x1GE MPA.
Sam
smilstea
Hi Jordi,
Sam
Hi Sam,
thanks a lot for the quick reply.
Jordi
