ASR 9001 throughput capacity
Sam Preston
1st QUESTION:
The ASR 9001 maximum throughput capacity is supposed to be 120 Gbps (60 Gbps per NP).
But surprisingly, I found a document from Cisco stating that the max capacity of this device is 240 Gbps : http://www.cisco.com/c/en/us/products/routers/asr-9000-series-aggregation-services-routers/models-comparison.html
What's wrong please? Is it a matter of duplex? Not clear.
2nd QUESTION:
Is the A9K-MPA-2x40GE supported on ASR-9001 or not? Despite having heavily searched the web, I was unable to find any clear statement on that. Of course it the answer to question 1 is that the limit is 120 Gbps (60 Gbps per NP) then this MPA cannot be supported by the ASR 9001.
Thanks for your help.
smailmilak
Level 4
Level 4
Answer for 1st question
ASR 9001 has 120G throughput. 240G is a marketing trick :)
Answer for 2nd question
I did a quick check on CCW and only these four MPA's are supported
A9K-MPA-20x1GE
A9K-MPA-2x10GE
A9K-MPA-4x10GE
A9K-MPA-1x40GE
smailmilak
Level 4
Level 4
A9K-MPA-20x1GE
A9K-MPA-2x10GE
A9K-MPA-4x10GE
A9K-MPA-1x40GE
A9K-MPA-8x10GE still not support?
Thank you very much.
It is not, and will never be.
