load balancing methods for port channel members on ASR1006
O.Zang
Hello Expert,
I have configure Port-channel with 4Tengig interfaces.
I have somme 3 interface working well, with lot of traffic. But on 1 interface, we are not receiving enougth Packet.
I have : 5 minute output rate 0 bits/sec, 0 packets/sec.
I have change interface but that same issue.
Can you please Help solve this ?
Zanga
6 Replies 6
balaji.bandi
Can you post below output :
show version
show running-config interface port-channel X (x is your Port-channel number)
show etherchannel load-balancing
show interface port-channel 2 etherchannel
also let us know what device other side connected with more information and config other sde too.
BB
Hello BB,
Attached are the ouputs.
Thanks for your support.
Zang
Hello BB,
Do you had time to check please ?
I just post output:
ASR1006#Sho run int po7
Building configuration...
Current configuration : 442 bytes
interface Port-channel7
description
ip address
ip router isis ISNET
ip flow monitor netflow sampler netflow input
ip policy route-map UPLOAD_TRAF
ipv6 address
ipv6 router isis ISNET
isis circuit-type level-2-only
isis network point-to-point
isis authentication mode md5
isis authentication key-chain ON
++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++Sho run int Te2/0/2+++++++++++++++++++++++++++++++++++++++++++
ASR1006#Sho run int Te2/0/2
Current configuration : 143 bytes
interface TenGigabitEthernet2/0/2
description <<to WS-6500 Te2/4/1>>
no ip address
channel-group 7 mode active
+++++++++++++++++++++++++++++++++++++++++++++++++++++++ sh etherchannel load-balancing +++++++++++++++++++++++++++++++++++
ASR1006#sh etherchannel load-balancing
EtherChannel Load-Balancing Method:
Global LB Method: flow-based
LB Algo type: Source Destination IP
Port-Channel: LB Method
Port-channel2 : flow-based (Source Destination IP)
Port-channel3 : flow-based (Source Destination IP)
Port-channel4 : flow-based (Source Destination IP)
Port-channel5 : flow-based (Source Destination IP)
Port-channel7 : flow-based (Source Destination IP)
Port-channel8 : flow-based (Source Destination IP)
++++++++++++++++++++++++++++++++++++ sho ver+++++++++++++++
sh version
Cisco IOS XE Software, Version 03.16.10.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.5(3)S10, RELEASE SOFTWARE (fc3)
Thanks for Help.
Zanga
High level, for now, i only see inconsistency on the config interface TenGigabitEthernet1/4/1 compare to others
disconnect the port and default the information and put the configuration from the work port and test it.
later day i will look deep and let you know if i see anything abnormal
can you also post-show module from cisco switch side.
BB
Hello BB,
I have already tried that. I have change  interfaces on both side ( Switch and router). but that the same result.
Zang
2 suggestions :
1. Configure different port from different module and join to teh Port-channel by removing (not working one)
2. at maintenance window, shutdown Port-channel both end and check
BB
