08-27-2020 12:55 PM - edited 08-27-2020 12:56 PM
Hi, everyone, I wanted to check out the following. Before consulting, I'll explain the topology and how it's configured. I have a network of ASR9000v satellites, connected at both ends by ASR9001 acting as hosts.
In both ends the connection is made by the TenGiga ports of the 9000v and a TenGiga port of the 9001 is used. I am trying to increase the capacity of this link from 10G to 20G, but I find that I cannot configure a bundle-eth and associate it to nv with a satellite "network".
This is:
Host(9001)<--10G-->9000v<--1G-->9000v<--1G-->9000v<--1G-->9000v<--10G-->Host(9001)
and I need to scale this to:
Host(9001)<--20G-->9000v<--1G-->9000v<--1G-->9000v<--1G-->9000v<--20G-->Host(9001)
The idea of configuration is the following:
interface TenGigE0/0/2/2
bundle id 50 mode on
interface TenGigE0/0/2/3
interface Bundle-Ether50
ipv4 point-to-point
ipv4 unnumbered Loopback100
nv
satellite-fabric-link network
redundancy
iccp-group 2
satellite 109
remote-ports GigabitEthernet 0/0/0-43
satellite 110
satellite 112
satellite 128
satellite 129
satellite 132
satellite 135
satellite 136
satellite 137
Actually, the config is:
ipv4 point-to-point
nv
redundancy
iccp-group 2
satellite 109
satellite 110
satellite 112
satellite 128
satellite 129
satellite 132
satellite 135
satellite 136
satellite 137
If someone had the same situation or came to need to do this and knew how to increase the BW of that link at both ends would appreciate commenting on how to do.
Solved! Go to Solution.
08-30-2020 08:45 AM
Hi Gustavo,
we have the asr9k, 9000v and a client a server for example.
it is referring to having the server with a bundle/lacp link between the server and the 9000v.
the configuration is straight forwards
gig101/0/0/0
bundle id <> mode active
gig101/0/0/2
08-28-2020 04:56 AM
This is a limitation listed
08-28-2020 05:06 AM
tkarnani first of all, thanks for your answer. yes, i found this information in the official documentation but i dont found information about sat-ether port bundle. In most cases i read about configure or how to establish bundle but one satellite conected to one Host. Again if you can explain how to establish sat-ether port bundle i'd appreciate it.
thanks in advance
Gustavo
08-30-2020 08:45 AM
Hi Gustavo,
gig101/0/0/0
gig101/0/0/2
