08-21-2023 03:05 AM - edited 08-21-2023 03:28 AM
We have a shutdown unused ASR 9010 with 2 line cards consisting A9K-MOD160-SE(A9K-MPA-20X1GE+A9K-MPA-8X10GE). Also we have a running ASR 9006 with 2 line cards A9K-4T16GE-SE. As in this 9006 ASR we already used all 8 10G ports, we have inserted a free line caed A9K-MOD160-SE(A9K-MPA-20X1GE+A9K-MPA-8X10GE) from the shutdown ASR 9010 to runnging ASR 9006 slot 0/2/CPU0. However all the 10G and 1G ports are not coming up in this line card. When checking the phy parameter of any port even when all the ports are no shut, none of them are transmitting and showing Oper. Status/Control: Tx Disabled, LOS,
Please find the phy snap. Please ignore the Rx Power value as at present patch cord not connected. Even when its connected Rx Power is showing but no Tx power
RP/0/RSP1/CPU0:ASR9060#show controllers Te0/2/1/2 phy
Mon Aug 21 15:20:53.844 IST
PHY data for interface: TenGigE0/2/1/2
SFP EEPROM port: 2
Xcvr Type: SFP
Xcvr Code: SFP-10G-LR
Encoding: 64B66B
Bit Rate: 10300 Mbps
Link Reach 9u fiber (Km): 10000 meter
Link Reach 9u fiber (100m): 10000 meter
Vendor Name: CISCO-FINISAR
Vendor OUI: 00.90.65
Vendor Part Number: FTLX1474D3BCL-C2 (rev.: A )
Laser wavelength: 1310 nm (fraction: 0.00 nm)
Optional SFP Signal: Tx_Disable, Tx_Fault, LOS
Vendor Serial Number: FNS20060BJN
Date Code (yy/mm/dd): 16/02/01 lot code:
Diagnostic Monitoring: DOM, Int. Cal.,
Enhanced Options: SW TX Fault Mon, SW TX Disable, Alarm/Warning Flags
MSA Data
0x0000: 03 04 07 20 00 00 00 00 : 00 00 00 06 67 00 0a 64
0x0010: 00 00 00 00 43 49 53 43 : 4f 2d 46 49 4e 49 53 41
0x0020: 52 20 20 20 00 00 90 65 : 46 54 4c 58 31 34 37 34
0x0030: 44 33 42 43 4c 2d 43 32 : 41 20 20 20 05 1e 00 c4
0x0040: 00 1a 00 00 46 4e 53 32 : 30 30 36 30 42 4a 4e 20
0x0050: 20 20 20 20 31 36 30 32 : 30 31 20 20 68 e0 03 28
0x0060: 00 00 02 7f f6 0e 94 90 : d5 38 9c 6b 81 4d 41 5f
0x0070: f7 ff 24 00 00 00 00 00 : 00 00 00 00 d7 a6 c7 f9
Thresholds: Alarm High Warning High Warning Low Alarm Low
Temperature: +75.000 C +70.000 C +0.000 C -5.000 C
Voltage: 3.630 Volt 3.465 Volt 3.135 Volt 2.970 Volt
Bias: 70.000 mAmps 68.000 mAmps 2.000 mAmps 1.000 mAmps
Transmit Power: 2.23870 mW (3.49996 dBm) 1.12200 mW (0.49993 dBm) 0.15140 mW (-8.19874 dBm) 0.06030 mW (-12.19683 dBm)
Receive Power: 2.23870 mW (3.49996 dBm) 1.12200 mW (0.49993 dBm) 0.03630 mW (-14.40093 dBm) 0.01450 mW (-18.38632 dBm)
Temperature: 34.199
Voltage: 3.309 Volt
Tx Bias: 0.000 mAmps
Tx Power: 0.000 mW (<-40.00 dBm)
Rx Power: 0.00290 mW (-25.37602 dBm)
EEPROM Memory (A2 lower)
0x0100: 4b 00 fb 00 46 00 00 00 : 8d cc 74 04 87 5a 7a 76
0x0110: 88 b8 01 f4 84 d0 03 e8 : 57 73 02 5b 2b d4 05 ea
0x0120: 57 73 00 91 2b d4 01 6b : 00 00 00 00 00 00 00 00
0x0130: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0140: 00 00 00 00 3f 80 00 00 : 00 00 00 00 01 00 00 00
0x0150: 01 00 00 00 01 00 00 00 : 01 00 00 00 00 00 00 40
0x0160: 22 33 81 42 00 00 00 00 : 00 1d 00 00 00 00 82 00
0x0170: 05 40 00 00 05 40 00 00 : ff ff ff ff ff ff ff 01
CLEI Code: COUIA75CAA
Part Number: 10-2457-02 (ver.: V02 )
Temp/Alarm/Power Flags: COM, commercial 0C to 70C
Minimum Temperature: 0
Maximum Temperature: 70
Calibration Constants:
Product Id: SFP-10G-LR
EEPROM Memory (A2 upper)
0x0180: 43 4f 55 49 41 37 35 43 : 41 41 31 30 2d 32 34 35
0x0190: 37 2d 30 32 56 30 32 20 : 01 00 46 00 00 00 00 b0
0x01a0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x01b0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 aa aa
0x01c0: 53 46 50 2d 31 30 47 2d : 4c 52 20 20 20 20 20 20
0x01d0: 20 20 20 20 34 38 00 00 : 00 00 00 00 00 00 00 35
0x01e0: 1e 20 2a 2a 31 34 29 36 : 00 00 00 00 00 00 00 00
0x01f0: 00 00 00 00 00 56 00 00 : ff ff ff ff 00 00 00 00
08-21-2023 06:21 AM
Hello @abhishekrakshit2,
Please provide #show license command output.
Thanks.
08-21-2023 06:32 AM
RP/0/RSP1/CPU0:ASR9006#show license
Mon Aug 21 19:01:18.225 IST
FeatureID: A9K-2T-SE-LIC (Slot based, Permanent)
Total licenses 2
Available for use 0
Allocated to location 0
Active 2
Store name Permanent
Store index 1
Pool: Owner
Total licenses in pool: 2
Status: Available 0 Operational: 2
Locations with licenses: (Active/Allocated) [SDR]
0/1/CPU0 (1/0) [Owner]
0/0/CPU0 (1/0) [Owner]
FeatureID: A9K-4T16GE-AIP-SE (Slot based, Permanent)
Total licenses 2
Available for use 2
Active 0
Store index 2
Pool: Owner
Status: Available 2 Operational: 0
FeatureID: A9K-MOBILE-LIC (Slot based, Permanent)
Total licenses 1
Available for use 1
Active 0
Store index 3
Pool: Owner
Total licenses in pool: 1
Status: Available 1 Operational: 0
08-21-2023 06:49 AM - edited 08-21-2023 06:54 AM
Do you try to Reset the card ?
Do the ASR9010 have license associated with the line carf A9K-MOD160-SE(A9K-MPA-20X1GE+A9K-MPA-8X10GE) ?
08-21-2023 07:00 AM - edited 08-21-2023 07:02 AM
Yes I did try by reloading this line card however no result
However after your suggestion, I have checked and existing ASR 9010 and found the license A9K-MOD160-AIP-SE. As I have posted in the 9006 its not present. Is this card not working due to this? And if its the case, please suggest how to transfer this license from shutdown 9010 to this running 9006?
RP/0/RSP1/CPU0:ASR9010#show license
Mon Aug 21 19:04:58.946 IST
Total licenses 1
Available for use 1
Active 0
Store index 1
Pool: Owner
FeatureID: A9K-MOD160-AIP-SE (Slot based, Permanent)
Total licenses 2
Available for use 0
Active 2
Store index 2
Pool: Owner
08-21-2023 07:12 AM
This license could indeed be required for the proper operation of the line card "A9K-MOD160-SE(A9K-MPA-20X1GE+A9K-MPA-8X10GE)" on the ASR 9006.
Transferring licenses from one device to another typically involves contacting Cisco's licensing support. They will guide you through the process and assist with any necessary license transfers or updates. You'll need to provide them with relevant information about the devices, such as serial numbers, current licenses, and desired license transfers.
To initiate this process, you can contact Cisco's technical support or your Cisco reseller. They will be able to assist you further and ensure that the appropriate licenses are correctly assigned to your devices.
08-21-2023 10:36 AM
While it is recommended to re-host the license with the help of the licensing team, it is not required for operation. The license in question is for VRFs and the license is not hard enforced. Can you share show pfm loc all and the software version?
Sam
08-21-2023 11:00 AM
08-21-2023 07:57 PM
Please find-
RP/0/RSP1/CPU0:ASR9006#show pfm loc all
Tue Aug 22 08:23:44.184 IST
node: node0_RSP1_CPU0
CURRENT TIME: Aug 22 08:23:44 2023
PFM TOTAL: 5 EMERGENCY/ALERT(E/A): 3 CRITICAL(CR): 0 ERROR(ER): 2
Raised Time |S#|Fault Name |Sev|Proc_ID|Dev/Path Name |Handle
Aug 21 14:40:47 2023|1 |CPI_NOT_READY |ER |36897 |Line Card and |0x1026004
Aug 21 15:00:16 2023|1 |SERDES_ERROR_LNK1 |E/A|204887 |Crossbar Switc|0x1017017
Aug 21 15:00:16 2023|1 |SERDES_ERROR_LNK0 |E/A|204887 |Crossbar Switc|0x101701b
Aug 21 15:00:16 2023|1 |SERDES_ERROR_LNK0 |E/A|204887 |Crossbar Switc|0x101702f
Aug 21 15:00:39 2023|1 |PUNT_FABRIC_DATA_PATH_FAILED |ER |225417 |System Punt/Fa|0x2000004
node: node0_0_CPU0
PFM TOTAL: 2 EMERGENCY/ALERT(E/A): 0 CRITICAL(CR): 0 ERROR(ER): 2
Jul 15 00:37:28 2023|2 |DEV_SFP_PID_NOT_SUPPORTED |ER |524427 |SFP |0x1029008
Aug 1 11:07:58 2023|2 |LOW_RX_POWER_WARNING |ER |168025 |SFP |0x1029005
node: node0_1_CPU0
PFM TOTAL: 5 EMERGENCY/ALERT(E/A): 0 CRITICAL(CR): 1 ERROR(ER): 4
Jul 15 00:37:18 2023|3 |DEV_SFP_SUPPORTED_ERROR |ER |516232 |SFP |0x1029009
Jul 15 00:37:18 2023|3 |DEV_SFP_PID_NOT_SUPPORTED |ER |516232 |SFP |0x1029009
Jul 15 00:37:21 2023|3 |DEV_SFP_SUPPORTED_ERROR |ER |516232 |SFP |0x102900d
Jul 15 00:37:21 2023|3 |DEV_SFP_PID_NOT_SUPPORTED |ER |516232 |SFP |0x102900d
Jul 15 00:37:24 2023|3 |LOW_RX_POWER_ALARM |CR |168025 |SFP |0x1029004
node: node0_2_CPU0
PFM TOTAL: 5 EMERGENCY/ALERT(E/A): 4 CRITICAL(CR): 1 ERROR(ER): 0
Aug 21 14:57:53 2023|4 |MISC_ERROR |CR |45089 |DB Controller |0x1047000
Aug 21 14:58:03 2023|4 |SERDES_ERROR_LNK1 |E/A|168016 |Crossbar Switc|0x101700f
Aug 21 14:58:16 2023|4 |SERDES_ERROR_LNK0 |E/A|168016 |Crossbar Switc|0x101700b
Aug 21 14:58:18 2023|4 |SERDES_ERROR_LNK1 |E/A|168016 |Crossbar Switc|0x1017007
Aug 21 14:58:18 2023|4 |SERDES_ERROR_LNK0 |E/A|168016 |Crossbar Switc|0x1017011
RP/0/RSP1/CPU0:ASR9006#sh ver
Tue Aug 22 08:25:26.082 IST
Cisco IOS XR Software, Version 6.5.3[Default]
Copyright (c) 2019 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 10.65(c) 1994-2014 by Cisco Systems, Inc.
ASR9006 uptime is 1 week, 3 days, 15 hours, 22 minutes
System image file is "disk0:asr9k-os-mbi-6.5.3/0x100305/mbiasr9k-rsp3.vm"
cisco ASR9K Series (Intel 686 F6M14S4) processor with 33554432K bytes of memory.
Intel 686 F6M14S4 processor at 1904MHz, Revision 2.174
ASR 9006 4 Line Card Slot Chassis with V2 DC PEM
2 Management Ethernet
1 FastEthernet
52 GigabitEthernet
16 TenGigE
16 WANPHY controller(s)
8 DWDM controller(s)
375k bytes of non-volatile configuration memory.
6271M bytes of hard disk.
25012208k bytes of disk0: (Sector size 512 bytes).
25012208k bytes of disk1: (Sector size 512 bytes).
Configuration register on node 0/RSP1/CPU0 is 0x2102
Boot device on node 0/RSP1/CPU0 is disk0:
Package active on node 0/RSP1/CPU0:
iosxr-adv-video, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-adv-video-6.5.3
Built on Tue Mar 26 20:07:14 IST 2019
By iox-ucs-017 in /auto/srcarchive13/prod/6.5.3/asr9k-px/ws for pie
asr9k-adv-video-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-adv-video-supp-6.5.3
asr9k-video-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-video-px-6.5.3
Built on Tue Mar 26 20:07:22 IST 2019
iosxr-service, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-service-6.5.3
Built on Tue Mar 26 20:05:43 IST 2019
asr9k-service-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-service-supp-6.5.3
asr9k-services-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-services-px-6.5.3
Built on Tue Mar 26 20:05:52 IST 2019
asr9k-optics-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-optics-supp-6.5.3
Built on Tue Mar 26 20:24:33 IST 2019
asr9k-optic-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-optic-px-6.5.3
Built on Tue Mar 26 20:24:52 IST 2019
iosxr-mpls, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-mpls-6.5.3
Built on Tue Mar 26 20:16:51 IST 2019
asr9k-mpls-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mpls-px-6.5.3
Built on Tue Mar 26 20:17:46 IST 2019
iosxr-infra, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-infra-6.5.3
Built on Tue Mar 26 20:45:15 IST 2019
iosxr-fwding, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-fwding-6.5.3
iosxr-routing, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-routing-6.5.3
iosxr-diags, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-diags-6.5.3
iosxr-ce, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-ce-6.5.3
iosxr-gcp-fwding, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-gcp-fwding-6.5.3
iosxr-common-pd-fib, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-common-pd-fib-6.5.3
asr9k-os-mbi, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-os-mbi-6.5.3
Built on Tue Mar 26 20:48:10 IST 2019
asr9k-base, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-base-6.5.3
asr9k-fwding, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-fwding-6.5.3
asr9k-diags-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-diags-supp-6.5.3
asr9k-scfclient, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-scfclient-6.5.3
asr9k-cpp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-cpp-6.5.3
asr9k-ce, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-ce-6.5.3
asr9k-mini-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mini-px-6.5.3
Built on Tue Mar 26 20:48:50 IST 2019
iosxr-mgbl, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-mgbl-6.5.3
Built on Tue Mar 26 20:08:00 IST 2019
asr9k-mgbl-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mgbl-supp-6.5.3
asr9k-mgbl-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mgbl-px-6.5.3
Built on Tue Mar 26 20:08:44 IST 2019
iosxr-mcast, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-mcast-6.5.3
Built on Tue Mar 26 20:07:30 IST 2019
asr9k-mcast-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mcast-supp-6.5.3
asr9k-mcast-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mcast-px-6.5.3
Built on Tue Mar 26 20:07:52 IST 2019
iosxr-li, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-li-6.5.3
Built on Tue Mar 26 20:06:35 IST 2019
asr9k-li, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-li-6.5.3
asr9k-li-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-li-px-6.5.3
Built on Tue Mar 26 20:06:44 IST 2019
iosxr-security, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-security-6.5.3
Built on Tue Mar 26 20:06:00 IST 2019
asr9k-k9sec-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-k9sec-supp-6.5.3
asr9k-k9sec-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-k9sec-px-6.5.3
Built on Tue Mar 26 20:06:27 IST 2019
asr9k-fpd, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-fpd-6.5.3
Built on Tue Mar 26 20:08:52 IST 2019
asr9k-fpd-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-fpd-px-6.5.3
Built on Tue Mar 26 20:09:53 IST 2019
asr9K-doc-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9K-doc-supp-6.5.3
Built on Tue Mar 26 20:05:27 IST 2019
asr9k-doc-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-doc-px-6.5.3
Built on Tue Mar 26 20:05:37 IST 2019
iosxr-bng, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-bng-6.5.3
Built on Tue Mar 26 20:05:01 IST 2019
asr9k-bng, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-bng-6.5.3
asr9k-bng-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-bng-px-6.5.3
Built on Tue Mar 26 20:05:19 IST 2019
asr9k-9000v-nV-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-9000v-nV-supp-6.5.3
Built on Tue Mar 26 20:06:51 IST 2019
asr9k-9000v-nV-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-9000v-nV-px-6.5.3
Built on Tue Mar 26 20:07:05 IST 2019
asr9k-services-infra, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-services-infra-6.5.3
Built on Tue Mar 26 20:14:31 IST 2019
Boot device on node 0/0/CPU0 is mem:
Package active on node 0/0/CPU0:
Boot device on node 0/1/CPU0 is mem:
Package active on node 0/1/CPU0:
Boot device on node 0/2/CPU0 is mem:
Package active on node 0/2/CPU0:
08-22-2023 12:47 PM
I see only 1 RSP? RSP1 is reporting serdes errors on the fabric and a punt data path failure to a LC (I can only assume LC2 based on it also showing serdes errors). Most likely this is some physical seating issue of the RSP or LC, we can also try the LC in a different slot after verifying the pins and connections on the back of the card / chassis arent bent in any way. If you look back in syslog to the 21st you should see the raising of these alarms with an indication of which cards are impacted.
Sam
08-22-2023 08:15 PM
Please ignore the first snap. In that time the 0/RSP0/CPU0 card was in IN_RESET mode. It was made up by reloading.
As per your suggestion, we will check by inserting the A9K-MOD160-SE card at line card slot 0/3/CPU0
RP/0/RSP1/CPU0:ASR9060#admin show platform
Wed Aug 23 08:43:48.125 IST
Node Type State Config State
0/RSP0/CPU0 A9K-RSP880-SE(Standby) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP880-SE(Active) IOS XR RUN PWR,NSHUT,MON
0/FT0/SP ASR-9006-FAN-V2 READY
0/0/CPU0 A9K-4T16GE-SE IOS XR RUN PWR,NSHUT,MON
0/1/CPU0 A9K-4T16GE-SE IOS XR RUN PWR,NSHUT,MON
0/2/CPU0 A9K-MOD160-SE IOS XR RUN PWR,NSHUT,MON
0/2/0 A9K-MPA-20X1GE OK PWR,NSHUT,MON
0/2/1 A9K-MPA-8X10GE OK PWR,NSHUT,MON
0/PS0/M0/SP PWR-2KW-DC-V2 READY PWR,NSHUT,MON
0/PS0/M1/SP PWR-2KW-DC-V2 READY PWR,NSHUT,MON
0/PS0/M2/SP PWR-2KW-DC-V2 READY PWR,NSHUT,MON
0/PS0/M3/SP PWR-2KW-DC-V2 READY PWR,NSHUT,MON
08-23-2023 03:21 AM
I tried by inserting the card at slot 0/3/CPU0, but port not came up at there also. However when I reverted back to 0/2/CPU0, the ports came up!
RP/0/RSP1/CPU0:ASR9006#show controllers Te0/2/1/0 phy | i Tx Power
Wed Aug 23 13:12:21.554 IST
Tx Power: 0.57080 mW (-2.43516 dBm)
RP/0/RSP1/CPU0:ASR9006#show ospf neighbor detail Te0/2/1/0
Wed Aug 23 13:02:00.462 IST
* Indicates MADJ interface
# Indicates Neighbor awaiting BFD session up
Neighbors for OSPF 100
Neighbor 220.224.15.186, interface address x.x.x.x
In the area 0.0.4.16 via interface TenGigE0/2/1/0
Neighbor priority is 1, State is FULL, 6 state changes
DR is 0.0.0.0 BDR is 0.0.0.0
Options is 0x42
Dead timer due in 00:00:37
Neighbor is up for 00:00:17
Number of DBD retrans during last exchange 0
Index 6/6, retransmission queue length 0, number of retransmission 0
First 0(0)/0(0) Next 0(0)/0(0)
Last retransmission scan length is 0, maximum is 0
Last retransmission scan time is 0 msec, maximum is 0 msec
LS Ack list: NSR-sync pending 0, high water mark 0
Total neighbor count: 1
08-21-2023 08:14 PM - edited 08-21-2023 08:16 PM
Please find-
Tue Aug 22 08:43:14.319 IST
CURRENT TIME: Aug 22 08:43:14 2023
node: node0_0_CPU0
node: node0_1_CPU0
node: node0_2_CPU0
PFM TOTAL: 9 EMERGENCY/ALERT(E/A): 8 CRITICAL(CR): 1 ERROR(ER): 0
Aug 22 08:35:59 2023|4 |SERDES_ERROR_LNK1 |E/A|168016 |Crossbar Switc|0x1017009
Aug 22 08:35:59 2023|4 |SERDES_ERROR_LNK0 |E/A|168016 |Crossbar Switc|0x101700c
Aug 22 08:35:59 2023|4 |SERDES_ERROR_LNK1 |E/A|168016 |Crossbar Switc|0x101700e
Aug 22 08:36:09 2023|4 |SERDES_ERROR_LNK0 |E/A|168016 |Crossbar Switc|0x1017010
node: node0_RSP0_CPU0
PFM TOTAL: 2 EMERGENCY/ALERT(E/A): 1 CRITICAL(CR): 0 ERROR(ER): 1
Aug 22 08:36:04 2023|0 |SERDES_ERROR_LNK0 |E/A|200832 |Crossbar Switc|0x101702f
Aug 22 08:38:14 2023|0 |PUNT_FABRIC_DATA_PATH_FAILED |ER |221321 |System Punt/Fa|0x2000004
Tue Aug 22 08:44:26.873 IST
ASR9006 uptime is 1 week, 3 days, 15 hours, 41 minutes
4 Management Ethernet
1 FastEthernet
52 GigabitEthernet
16 TenGigE
