ASR 9006 RPKI server in not default vrf
Serg_tsk
Dear colleagues, i've tried to implement rpki validation on ASR9k6 with iOS XR 6.4.2 32bit (RSP-440-se) and got fail.
All of my infra-devices and mgmt networks are placed into vrf "fake". I have RIPE rpki-validator-server in vrf fake. Can i specify rpki server option with vrf point ? I did't find how to do it. ( https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-4/routing/configuration/guide/b-routing-cg-asr9000-64x/b-routing-cg-asr9000-64x_chapter_010.html#task_40A84643C72641E2A09372847AA68F30 )
2nd question: all my external peers are placed into vrf "ext". Can the ASR check prefixes  which were received from not default VRF ? ( https://community.cisco.com/t5/routing/rpki-validation-for-neighbors-in-vrfs/td-p/2724218 )
Thank you. With best regards
Sergey
decode.chr13
Did you manage to solve RPKI in a VRF issue?
Maybe this helps...?
router bgp <asn>
 vrf ext
  bgp origin-as validation signal ibgp
  bgp bestpath origin-as use validity
  bgp bestpath origin-as allow invalid
  address-family ipv4 unicast
   bgp origin-as validation enable
  address-family ipv6 unicast
Thank you for your reply!
 The 1st problem with rpki-server connectivity was solved by placing rpki-validator into GRT. Another trick :)
The 2nd problem: there is no bgp-option in vrf context of router bgp config
RP/0/RSP0/CPU0:crt-c9006-1(config)#router bgp my_asn
RP/0/RSP0/CPU0:crt-c9006-1(config-bgp)#vrf ext
RP/0/RSP0/CPU0:crt-c9006-1(config-bgp-vrf)#bgp ?
  auto-policy-soft-reset  Enable automatic soft peer reset on policy reconfiguration
  bestpath                Change default route selection criteria
  default                 Configure default value
  enforce-first-as        Enforce the first AS for EBGP routes
  fast-external-fallover  Immediately reset session if a link to a directly connected external peer
 goes down
  log                     Log bgp info
  multipath               Change multipath selection criteria
  redistribute-internal   Allow redistribution of iBGP into IGPs (dangerous)
  router-id               Configure Router-id
  unsafe-ebgp-policy      Make eBGP neighbors with no policy pass all routes(cisco-support)
RP/0/RSP0/CPU0:crt-c9006-1(config-bgp-vrf)#bgp bestpath ?
  aigp              AIGP attribute
  as-path           AS path length
  compare-routerid  Compare router-id for identical EBGP paths
  cost-community    Cost community
  med               MED related
RP/0/RSP0/CPU0:crt-c9006-1(config-bgp-vrf)#address-family ipv4 unicast
RP/0/RSP0/CPU0:crt-c9006-1(config-bgp-vrf-af)#bgp ?
  attribute-download  Configure attribute download for this address-family
  dampening           Enable route-flap dampening
I talked with colleagues last week and received information from them that origin-as validation works in iOS XR 6.5.1. But my RSP440-SE can't run this software. 6.4.2 - is the last supported :(
Thank you.
With best regards, Sergey.
decode.chr13
Regarding: "Can i specify rpki server option with vrf point?", I think the answer is no, but you can use a trick.
rpki server <10.1.1.101> transport ssh port <999>
than configure ssh client source interface using a "fake" vrf interface:
ssh client source-interface <MgmtEth0/RP0/CPU0/0>
interface MgmtEth0/RP0/CPU0/0
vrf fake
ipv4 address 10.0.11.111 255.255.255.0
load-interval 30
