ASR9001 BNG over Xconnect (Two sites) with Geo-Redundancy
startx001
HI ,
Have anyone implemented this kind of deployment ?
I asking because i saw that use cases can be MSTAG or MSLAG and i would like to use MSTAG because i need solution load sharing with standby-hot.
Can anyone tell me is it working when using xconnect as pppoe transport, and how is this done ?
Im interested most in how pppoe session will switch from active to standby chassis in this concept or i should use BNG cluster instead ?
Im planning  to use XR version 6.4.4.screen_shot_2016-04-18_at_9.56.17_am.png
antonio.kucar
Hello startx001,
Did you find a working solution when using xconnect as pppoe transport?
Did you transport multiple VLANs over xconnect from one side (access/modems) to other side (BNGs)?
I am planning a similar setup so I wonder how it works at yours ASR9ks.
BR,
Antonio
Hello startx001,
You can use pseudowire redundancy with active/backup pseudowire :
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/lxvpn/configuration/guide/lesc43xbook/lesc43p2ps.html#pgfId-1262000
If you access network is pure L3/MPLS you can use Pseudowire Headend in order to terminate your services on the BNG :
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/lxvpn/configuration/guide/lesc43xbook/lesc43p2mps.html#pgfId-1341764
Michalis
