ASR9001 module A9K-MPA-20X1GE issue
a_prutkoy
Hi all!
Who knows, what does these messages mean?
LC/0/0/CPU0:Oct 22 10:53:32.120 : envmon_lc[160]: %PLATFORM-ENVMON-4-OPERATION_WARN : Unable to get plug sensor data, error code 'Subsystem(2890)' detected the 'fatal' condition 'Code(0)'
RP/0/RSP0/CPU0:Oct 22 10:53:32.860 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 A9K-MPA-20X1GE state:ADMIN DOWN
LC/0/0/CPU0:Oct 22 10:53:32.862 : lda_server[65]: %PLATFORM-LDA-3-MPA_BAY_SW_ERROR : Unable to initialize MPA in bay: 0, Module has been shutdown due to identify test failure (0x00000000 - No error)  : pkg/bin/lda_server : (PID=40990) :  -Traceback= 4ed5159c 4bf1eed0 4bf1efdc 4d02c28c 4d02a1f4 4ba73a44 4ba71554 4d029ddc 4bada400
RP/0/RSP0/CPU0:Oct 22 10:53:33.860 : invmgr[250]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/0/0, state: UNPOWERED
Is this hardware or software issue? What do you think?
I think we have faced with hardware issue of module A9K-MPA-20X1GE.
More outputs:
RP/0/RSP0/CPU0:asr9001#sh ver
Tue Oct 22 10:53:46.186 UTC
Cisco IOS XR Software, Version 4.3.2[Default]
Copyright (c) 2013 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 2.01(20130627:172232) [ASR9K ROMMON],
asr9001 uptime is 6 minutes
System image file is "bootflash:disk0/asr9k-os-mbi-4.3.2/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (P4040) processor with 8388608K bytes of memory.
P4040 processor at 1500MHz, Revision 2.0
ASR-9001 Chassis
2 Management Ethernet
4 TenGigE
4 DWDM controller(s)
4 WANPHY controller(s)
219k bytes of non-volatile configuration memory.
2880M bytes of hard disk.
3932144k bytes of disk0: (Sector size 512 bytes).
Configuration register on node 0/RSP0/CPU0 is 0x102
Boot device on node 0/RSP0/CPU0 is disk0:
Package active on node 0/RSP0/CPU0:
iosxr-infra, V 4.3.2[Default], Cisco Systems, at disk0:iosxr-infra-4.3.2
    Built on Sun Sep  1 19:21:10 UTC 2013
    By iox-bld2 in /auto/srcarchive7/production/4.3.2/all/workspace for pie
iosxr-fwding, V 4.3.2[Default], Cisco Systems, at disk0:iosxr-fwding-4.3.2
iosxr-routing, V 4.3.2[Default], Cisco Systems, at disk0:iosxr-routing-4.3.2
iosxr-diags, V 4.3.2[Default], Cisco Systems, at disk0:iosxr-diags-4.3.2
iosxr-ce, V 4.3.2[Default], Cisco Systems, at disk0:iosxr-ce-4.3.2
asr9k-os-mbi, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-os-mbi-4.3.2
    Built on Sun Sep  1 19:23:39 UTC 2013
asr9k-base, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-base-4.3.2
    Built on Sun Sep  1 19:21:14 UTC 2013
asr9k-fwding, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-fwding-4.3.2
asr9k-diags-supp, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-diags-supp-4.3.2
    Built on Sun Sep  1 19:21:19 UTC 2013
asr9k-scfclient, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-scfclient-4.3.2
    Built on Sun Sep  1 19:21:22 UTC 2013
asr9k-cpp, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-cpp-4.3.2
asr9k-ce, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-ce-4.3.2
    Built on Sun Sep  1 19:21:16 UTC 2013
asr9k-mini-px, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-mini-px-4.3.2
    Built on Sun Sep  1 19:27:30 UTC 2013
iosxr-mgbl, V 4.3.2[Default], Cisco Systems, at disk0:iosxr-mgbl-4.3.2
    Built on Sun Sep  1 19:28:25 UTC 2013
asr9k-mgbl-supp, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-mgbl-supp-4.3.2
asr9k-mgbl-px, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-mgbl-px-4.3.2
    Built on Sun Sep  1 19:28:37 UTC 2013
asr9k-fpd, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-fpd-4.3.2
    Built on Sun Sep  1 19:29:15 UTC 2013
asr9k-fpd-px, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-fpd-px-4.3.2
    Built on Sun Sep  1 19:29:40 UTC 2013
asr9K-doc-supp, V 4.3.2[Default], Cisco Systems, at disk0:asr9K-doc-supp-4.3.2
    Built on Sun Sep  1 19:29:07 UTC 2013
asr9k-doc-px, V 4.3.2[Default], Cisco Systems, at disk0:asr9k-doc-px-4.3.2
    Built on Sun Sep  1 19:29:14 UTC 2013
Boot device on node 0/0/CPU0 is mem:
Package active on node 0/0/CPU0:
RP/0/RSP0/CPU0:asr9001#sh log
Tue Oct 22 10:54:22.823 UTC
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
    Console logging: level warnings, 44 messages logged
    Monitor logging: level debugging, 0 messages logged
    Trap logging: level informational, 0 messages logged
    Buffer logging: level debugging, 148 messages logged
Log Buffer (307200 bytes):
RP/0/RSP0/CPU0:Oct 22 10:47:29.090 : init[65540]: %OS-INIT-7-MBI_STARTED : total time 8.814 seconds
RP/0/RSP0/CPU0:Oct 22 10:47:29.113 : imio[64]: %PLATFORM-IMIO-3-OPERATION_NOTIFY : imio_main: cold start
RP/0/RSP0/CPU0:Oct 22 10:48:42.672 : sysmgr[96]: %OS-SYSMGR-5-NOTICE : Card is COLD started
RP/0/RSP0/CPU0:Oct 22 10:48:50.075 : init[65540]: %OS-INIT-7-INSTALL_READY : total time 89.801 seconds
RP/0/RSP0/CPU0:Oct 22 10:48:51.803 : sysmgr[407]: %OS-SYSMGR-6-INFO : Backup system manager is ready
RP/0/RSP0/CPU0:Oct 22 10:48:52.088 : sc_reddrv[376]: imio_lance2_init_interrupts:
RP/0/RSP0/CPU0:Oct 22 10:48:58.262 : sysmgr[96]: %OS-SYSMGR-7-DEBUG : node set to DSC
RP/0/RSP0/CPU0:Oct 22 10:49:04.763 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-SYSTEM_COLD_START : System cold start detected.  Resetting Line Cards.
RP/0/RSP0/CPU0:Oct 22 10:49:06.487 : pwr_mgmt[360]: %PLATFORM-PWR_MGMT-2-MODULE_FAILURE : Power-module 0/PM1/SP failure condition raised : Module input voltage out of range
RP/0/RSP0/CPU0:Oct 22 10:49:07.565 : online_diag_rsp[427]: %DIAG-DIAG-6-RUN_MINIMUM : ASR9001-RP 0/RSP0/CPU0: Running Minimum Diagnostics...
RP/0/RSP0/CPU0:Oct 22 10:49:09.369 : envmon[204]: %PLATFORM-ENVMON-4-FANTRAY_RPM : Fan tray RPM warning on slot 0/FT0/SP
RP/0/RSP0/CPU0:Oct 22 10:49:12.761 : bpe[144]: %PLATFORM-BPE-5-INFO : successfully retrieved i2c eeprom
RP/0/RSP0/CPU0:Oct 22 10:49:12.969 : shelfmgr[381]: %PLATFORM-SHELFMGR_HAL-7-CAN_INFO : Can API: slot 0 online event.
RP/0/RSP0/CPU0:Oct 22 10:49:12.991 : shelfmgr[381]: %PLATFORM-SHELFMGR_HAL-3-POWER_SUPPLY_REDUNDANCY : Power Supply Failures are not protected.
RP/0/RSP0/CPU0:Oct 22 10:49:13.624 : invmgr[250]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/FT0/SP inserted
RP/0/RSP0/CPU0:Oct 22 10:49:13.780 : invmgr[250]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/PM0/SP inserted
RP/0/RSP0/CPU0:Oct 22 10:49:13.788 : invmgr[250]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/PM1/SP, state: FAILED
RP/0/RSP0/CPU0:Oct 22 10:49:13.789 : invmgr[250]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/PM1/SP inserted
RP/0/RSP0/CPU0:Oct 22 10:49:13.800 : invmgr[250]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/RSP0/CPU0, state: IOS XR RUN
RP/0/RSP0/CPU0:Oct 22 10:49:18.393 : envmon[204]: %PLATFORM-ENVMON-3-OPERATION_ERROR : Failed in envmon lwmconnect.message channel connection failed!,-1 error code 'Subsystem(8191)' detected the 'unknown' condition 'Code(63)': Unknown Error(511)
RP/0/RSP0/CPU0:Oct 22 10:49:19.395 : envmon[204]: %PLATFORM-ENVMON-3-OPERATION_FAIL : Failed in envmon_fantray_alarms.7076, error code 'Subsystem(8191)' detected the 'unknown' condition 'Code(63)': Unknown Error(511)
RP/0/RSP0/CPU0:Oct 22 10:49:19.395 : envmon[204]: %PLATFORM-ENVMON-2-ENV_CONDITION : Outstanding environmental condition exists in the chassis
RP/0/RSP0/CPU0:Oct 22 10:49:19.815 : invmgr[250]: lance_client_init: Client already connected
RP/0/RSP0/CPU0:Oct 22 10:49:20.816 : invmgr[250]: lance_client_init: Client already connected
RP/0/RSP0/CPU0:Oct 22 10:49:21.817 : invmgr[250]: lance_client_init: Client already connected
RP/0/RSP0/CPU0:Oct 22 10:49:22.843 : invmgr[250]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/RSP0/CPU0 inserted
RP/0/RSP0/CPU0:Oct 22 10:49:27.313 : sysmgr[96]: %OS-SYSMGR-7-DEBUG : sysmgr_admin_plane_check:SYSMGR_PLANE_ADMIN Notification sent.
RP/0/RSP0/CPU0:Oct 22 10:49:32.838 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_DISCOVERY : Node State Discovery complete
RP/0/RSP0/CPU0:Oct 22 10:49:32.854 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/CPU0 ASR9001-LC state:PRESENT
RP/0/RSP0/CPU0:Oct 22 10:49:32.905 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/FT0/SP FAN TRAY state:PRESENT
RP/0/RSP0/CPU0:Oct 22 10:49:32.957 : invmgr[250]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/0/CPU0 inserted
RP/0/RSP0/CPU0:Oct 22 10:49:35.224 : syslog_dev[94]: hsbi_fpd_agent[240]: FPD ltrace_file_name => fpd-agent/hsbi_fpd_agent
RP/0/RSP0/CPU0:Oct 22 10:49:37.310 : alphadisplay[115]: %PLATFORM-ALPHA_DISPLAY-6-CHANGE : Alpha display on node 0/RSP0/CPU0 changed to IOXR in state default
RP/0/RSP0/CPU0:Oct 22 10:49:48.759 : syslog_dev[94]: netio[327]: > WARNING (BM) [/ws/akgoswam-bgl/hellhound/nto6.4-XR/cisco/lib/3rdparty/netcomm/NetCommSw/Peripherals/BM/bm.h:352 BmBpidGet]: No Ipc - can't validate bpid.^M
RP/0/RSP0/CPU0:Oct 22 10:50:02.721 : ipodwdm[275]: %L2-G709-6-INFO : /harddisk:/ipodwdm_log  Already present
RP/0/RSP0/CPU0:Oct 22 10:50:03.698 : shelfmgr[381]: %PLATFORM-SHELFMGR_HAL-6-BOOT_REQ_RECEIVED : Boot Request from 0/0/CPU0, RomMon Version: 2.1
RP/0/RSP0/CPU0:Oct 22 10:50:04.481 : shelfmgr[381]: %PLATFORM-MBIMGR-7-IMAGE_VALIDATED : Remote location 0/0/CPU0: : MBI tftp:/disk0/asr9k-os-mbi-4.3.2/lc/mbiasr9k-lc.vm validated
RP/0/RSP0/CPU0:Oct 22 10:50:04.499 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/CPU0 ASR9001-LC state:MBI-BOOTING
RP/0/RSP0/CPU0:Oct 22 10:50:07.632 : alphadisplay[115]: %PLATFORM-ALPHA_DISPLAY-6-CHANGE : Alpha display on node 0/RSP0/CPU0 changed to ACTV in state default
RP/0/RSP0/CPU0:Oct 22 10:50:14.758 : canb-server[149]: %PLATFORM-CANB_SERVER-3-ALARM_CLEARED : Clear alarm from CBC in slot 0/FT0/SP, alarm code CBC_ALRM_FT_LED_RED_FAILED
RP/0/RSP0/CPU0:Oct 22 10:50:14.764 : canb-server[149]: %PLATFORM-CANB_SERVER-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/FT0/SP, alarm code CBC_ALRM_FT_LED_GREEN_FAILED
RP/0/RSP0/CPU0:Oct 22 10:50:29.223 : placed[346]: LR-PLANE-READY DECLARATION
RP/0/RSP0/CPU0:Oct 22 10:50:31.360 : envmon[204]: %PLATFORM-ENVMON-4-FANTRAY_RPM_CLEAR : Fan tray RPM warning cleared on slot 0/FT0/SP
RP/0/RSP0/CPU0:Oct 22 10:50:33.247 : ifmgr[242]: %PKT_INFRA-LINK-5-CHANGED : Interface MgmtEth0/RSP0/CPU0/1, changed state to Administratively Down
RP/0/RSP0/CPU0:Oct 22 10:50:33.251 : ifmgr[242]: %PKT_INFRA-LINK-3-UPDOWN : Interface MgmtEth0/RSP0/CPU0/0, changed state to Down
RP/0/RSP0/CPU0:Oct 22 10:50:33.251 : ifmgr[242]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface MgmtEth0/RSP0/CPU0/0, changed state to Down
RP/0/RSP0/CPU0:Oct 22 10:50:33.257 : cfgmgr-rp[158]: %MGBL-CONFIG-6-OIR_RESTORE : Configuration for node '0/RSP0/0' has been restored.
RP/0/RSP0/CPU0:Oct 22 10:50:35.006 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/PM1/SP A9K-750W-AC state:PRESENT
RP/0/RSP0/CPU0:Oct 22 10:50:35.012 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/PM0/SP A9K-750W-AC state:PRESENT
RP/0/RSP0/CPU0:Oct 22 10:50:35.588 : ifmgr[242]: %PKT_INFRA-LINK-3-UPDOWN : Interface MgmtEth0/RSP0/CPU0/0, changed state to Up
RP/0/RSP0/CPU0:Oct 22 10:50:35.589 : ifmgr[242]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface MgmtEth0/RSP0/CPU0/0, changed state to Up
RP/0/RSP0/CPU0:Oct 22 10:51:15.756 : canb-server[149]: %PLATFORM-CANB_SERVER-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/FT0/SP, alarm code CBC_ALRM_FT_LED_RED_FAILED
RP/0/RSP0/CPU0:Oct 22 10:51:15.756 : canb-server[149]: %PLATFORM-CANB_SERVER-3-ALARM_CLEARED : Clear alarm from CBC in slot 0/FT0/SP, alarm code CBC_ALRM_FT_LED_GREEN_FAILED
RP/0/RSP0/CPU0:Oct 22 10:51:23.316 : dsc[181]: %PLATFORM-DSC_CTRL-6-RACK_STATE :  Rack 1 is now Down
RP/0/RSP0/CPU0:Oct 22 10:51:23.321 : gsp[239]: gsp_rack_down_handler: for node:0x1
RP/0/RSP0/CPU0:Oct 22 10:51:25.396 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/CPU0 ASR9001-LC state:MBI-RUNNING
LC/0/0/CPU0:10: init[65540]: %OS-INIT-7-MBI_STARTED : total time 5.152 seconds
LC/0/0/CPU0:Oct 22 10:51:57.119 : sysmgr[91]: %OS-SYSMGR-5-NOTICE : Card is COLD started
LC/0/0/CPU0:Oct 22 10:51:57.524 : init[65540]: %OS-INIT-7-INSTALL_READY : total time 38.219 seconds
LC/0/0/CPU0:Oct 22 10:51:58.119 : sysmgr[341]: %OS-SYSMGR-6-INFO : Backup system manager is ready
RP/0/RSP0/CPU0:Oct 22 10:52:11.473 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 UNKNOWN state:UNPOWERED
RP/0/RSP0/CPU0:Oct 22 10:52:11.896 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 A9K-MPA-20X1GE state:POWER UP
LC/0/0/CPU0:Oct 22 10:52:12.716 : lda_server[65]: %L2-SPA-5-STATE_CHANGE : SPA in bay 0 type A9K-MPA-20X1GE Initing
RP/0/RSP0/CPU0:Oct 22 10:52:13.786 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 A9K-MPA-20X1GE state:INITIALIZED
LC/0/0/CPU0:Oct 22 10:52:25.265 : prm_server_ty[295]: %PLATFORM-QOSHAL-6-QOS_MODE_CHANGE : Line-card QoS mode set to child-shaping-enabled.
LC/0/0/CPU0:Oct 22 10:52:25.273 : prm_server_ty[295]: %PLATFORM-QOSHAL-6-QOS_MODE_CHANGE : Line-card QoS mode set to lowburst-disabled.
LC/0/0/CPU0:Oct 22 10:52:25.402 : lda_server[65]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : fpga3 instance 0 is down-rev (V0.07), upgrade to (V0.08). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/0/CPU0:Oct 22 10:52:25.632 : sysmgr[91]: %OS-SYSMGR-7-DEBUG : sysmgr_admin_plane_check:SYSMGR_PLANE_ADMIN Notification sent.
LC/0/0/CPU0:Oct 22 10:52:27.651 : syslog_dev[89]: hsbi_fpd_agent[198]: FPD ltrace_file_name => fpd-agent/hsbi_fpd_agent
RP/0/RSP0/CPU0:Oct 22 10:52:37.663 : exec[65727]: %MGBL-exec-3-LOGIN_AUTHEN : Login Authentication failed. Exiting...
RP/0/RSP0/CPU0:Oct 22 10:52:43.079 : exec[65727]: %SECURITY-login-6-AUTHEN_SUCCESS : Successfully authenticated user 'shopik' from 'console' on 'con0_RSP0_CPU0'
RP/0/RSP0/CPU0:Oct 22 10:52:46.558 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/0 A9K-MPA-20X1GE state:OK
RP/0/RSP0/CPU0:Oct 22 10:52:46.578 : invmgr[250]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/0/0, state: OK
RP/0/RSP0/CPU0:Oct 22 10:52:46.583 : invmgr[250]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/0/0 inserted
LC/0/0/CPU0:Oct 22 10:52:58.858 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface TenGigE0/0/2/3, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:58.863 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface TenGigE0/0/2/2, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:58.863 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface TenGigE0/0/2/1, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:58.863 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface TenGigE0/0/2/0, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.133 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/19, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.133 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/18, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.133 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/17, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.133 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/16, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.133 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/15, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/14, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/13, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/12, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/11, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/10, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/9, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/8, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/7, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.134 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/6, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.135 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/5, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.135 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/4, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.135 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/3, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.135 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/2, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.135 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/1, changed state to Administratively Down
LC/0/0/CPU0:Oct 22 10:52:59.135 : ifmgr[200]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/0, changed state to Administratively Down
RP/0/RSP0/CPU0:Oct 22 10:53:00.041 : upgrade_fpd_cli[65763]: %PLATFORM-UPGRADE_FPD-6-STATUS : FPD upgrade started.
LC/0/0/CPU0:Oct 22 10:53:01.800 : lda_server[65]: %PLATFORM-SCC-2-BAD_ID_HW : Failed Identification Test in 0/130/0 [5/0] The module in 0/130/0 in this router may not be a genuineCisco product.  Cisco warranties and support programs onlyapply to genuine Cisco products.  If Cisco determines thatyour insertion of non-Cisco SPA cards or other modules into aCisco product is the cause of a support issue, Cisco maydeny support under your warranty or under a Cisco supportprogram such as SmartNet.
RP/0/RSP0/CPU0:Oct 22 10:53:09.746 : shelfmgr[381]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/CPU0 ASR9001-LC state:IOS XR RUN
RP/0/RSP0/CPU0:Oct 22 10:53:09.755 : invmgr[250]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/0/CPU0, state: IOS XR RUN
LC/0/0/CPU0:Oct 22 10:53:31.822 : lda_server[65]: %PLATFORM-LDA-4-MPA_OIR_QUICK_BACK_TO_BACK_ERROR : OIR operation was performed on MPA in bay:0 while the system is initializing. Recommend waiting for two minutes after EP initialized.
LC/0/0/CPU0:Oct 22 10:53:31.988 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/19, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.988 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/19, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/18, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/18, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/17, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/17, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/16, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/16, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/15, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/15, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/14, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/14, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/13, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/13, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/12, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.990 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/11, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.989 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/12, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.990 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/11, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.990 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/10, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.990 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/10, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.990 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/9, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.990 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/9, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/8, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/8, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/7, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/7, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/6, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/5, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/5, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/4, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/4, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/6, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/3, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/3, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/2, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.991 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/2, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.992 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/1, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.992 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/1, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.992 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/0/0/0, changed state to Down
LC/0/0/CPU0:Oct 22 10:53:31.992 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/0/0/0, changed state to Down
RP/0/RSP0/CPU0:asr9001#show inventory
Tue Oct 22 11:01:32.251 UTC
NAME: "module 0/RSP0/CPU0", DESCR: "ASR 9001, Route Switch Processor with 8GB memory"
PID: ASR9001-RP, VID: V01 , SN: FOC1728XXXX
NAME: "module 0/0/CPU0", DESCR: "ASR 9001, Modular Line Card"
PID: ASR9001-LC, VID: V01 , SN: FOC1728XXXX
NAME: "module 0/0/0", DESCR: "ASR 9000 20-port 1GE Modular Port Adapter"
PID: A9K-MPA-20X1GE, VID: V00, SN: FOC1522XXXX
NAME: "module 0/0/2", DESCR: "ASR 9000 Virtual Module"
PID: A9K-MODULEv, VID: N/A, SN: N/A
It "disappears" because the MPA goes down due to the errors.  If you are getting the same in both slot 0 and slot 1, then we probablly need to replace that MPA.
Bryan
13 Replies 13
smilstea
Can you try the MPA in slot 1?
Sam
Hi Samuel,
Thanks! We'll try.
Samuel, we have tried the MPA in slot 1. We see the same issue.
Bryan Garland
There was a bug that was similar to this.  It was an FPD fix.  Can you get the output of:
show hw-module fpd location all
If you see any that say "yes" in the last column, you will need to upgrade the FPDs.
For the procedure on that:
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.0/system_management/configuration/guide/b_yc40asr9k_chapter_0111.html
Just please don't use the "force" keyword.
thanks,
Bryan
Hi Bryan,
Ok, thx, we'll check "show hw-module fpd location all" and I'll post the results.
Bryan,
We checked the "show hw-module fpd location all" and there is no "yes" in the last column.
http://pastebin.com/W1wuqYks
RP/0/RSP0/CPU0:asr9001#sh hw-module fpd location all
Thu Oct 24 13:40:19.487 UTC
                                      Existing Field Programmable Devices
                                        HW                       Current SW Upg/
Location     Card Type                Version Type Subtype Inst   Version   Dng?
0/RSP0/CPU0  ASR9001-RP                 1.0   lc   fpga2   0       1.14     No
                                              lc   cbc     0      22.114    No
                                              lc   rommon  0       2.01     No
0/FT0/SP     ASR-9001-FAN               1.0   ft   cbc     7      24.114    No
0/0/CPU0     ASR9001-LC                 1.0   lc   cbc     0      23.114    No
                                              lc   fpga2   0       1.18     No
                                              lc   fpga4   0       2.07     No
                                              lc   rommon  0       2.01     No
Bryan,
New update.
At some time we "Yes", but then it dissapeared from outputs. I think we will try to upgrade.
RP/0/RSP0/CPU0:asr9001#show hw-module fpd location all Thu Oct 24 14:11:38.703 UTC ===================================== ==========================================                                       Existing Field Programmable Devices                                       ==========================================                                         HW                       Current SW Upg/ Location     Card Type                Version Type Subtype Inst   Version   Dng? ============ ======================== ======= ==== ======= ==== =========== ==== 0/RSP0/CPU0  ASR9001-RP                 1.0   lc   fpga2   0       1.14     No                                               lc   cbc     0      22.114    No                                               lc   rommon  0       2.01     No -------------------------------------------------------------------------------- 0/FT0/SP     ASR-9001-FAN               1.0   ft   cbc     7      24.114    No -------------------------------------------------------------------------------- 0/0/CPU0     ASR9001-LC                 1.0   lc   cbc     0      23.114    No                                               lc   fpga2   0       1.18     No                                               lc   fpga4   0       2.07     No                                               lc   rommon  0       2.01     No -------------------------------------------------------------------------------- 0/0/0        A9K-MPA-20X1GE             1.0   spa  fpga3   0       0.07     Yes -------------------------------------------------------------------------------- NOTES: 1.  One or more FPD needs an upgrade or a downgrade.  This can be accomplished     using the "admin> upgrade hw-module fpd location " CLI.
Bryan
I had same issues with asr9001 and MPA-20x1G.
Try not screw so tight card to chassis.
Use 70% of screw.
This help me in few cases
In my opinion this is problem with 9001 chassis, because I had never seen this on 9006 and 9010.
Hi Bryan,
May i know why you are saying not to use force ? its not relevant to this scenario while we were upgrading 9006 RS440 we have noticed eventhough successfully FPD upgraded still it was showing old FPGA1 value. When i use force keyword it showed corrupted after the reload . But after OIR it was corrected.  Is there any issue related to issuing upgrade with force keyword ?
Gobinath.
Gobinath,
You really don't want to use force unless directed by support teams.  The reason is that force doesn't do any checking and if the FPD image is corrupted or the wrong one it will still get copied.  This can cause the card to not be recoverable.  Or at least not without more intrusive steps.
Bryan
a_prutkoy
Hi all,
We tried to upgrade FPD, but since the module disappears upgrade was failed. We tried not so tight card to chassis. Nothing help.
As a result we replaced the module and now it works fine.
Thanks all!
Glad to hear you got it resolved!
Bryan
