ASR9006 interface numbering
aacole
Level 5
Level 5
Can someone tell me how the ports on the ASR 9006 are numbered, I cannot find the exact information in the installation guide, and have never seen one of these units. I'm told that the subslot number on a 9K is always 0. I need to write a document showing which port connects to which circuit.
For a A9K-MOD80 in slot 3, the lowest line card slot:
Which way round are  module 1 and 2? Is 1 on the left or right?
What is the port number for the first 10G interface, first line card first module
What is the port number for the first Gigabit interface on a module fitted in module 2 on the first line card?
Hope the question is clear,
Andy
Alexei Kiritchenko
Hello Andy,
The node-id appears in the rack/slot/module notation, and the node-id components are as follows:
rack —In a single-shelf system the rack number is always “0.”
slot —Number of the physical slot in which the card is installed.
module —Subslot number of a system hardware component.
With SIP or MOD cards the subslot is used too.
Example:
RP/0/RSP1/CPU0:ariad#show plat
Thu Dec 13 21:23:42.927 CET
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP440-SE(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-SE(Active)     IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-24x10GE-TR            IOS XR RUN       PWR,NSHUT,MON
0/1/CPU0        A9K-24x10GE-SE            IOS XR RUN       PWR,NSHUT,MON
0/2/CPU0        A9K-4T-B                  IOS XR RUN       PWR,NSHUT,MON
0/3/CPU0        A9K-40GE-E                UNPOWERED        NPWR,NSHUT,MON
0/4/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/4/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/4/1           A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
0/5/CPU0        A9K-8T-L                  IOS XR RUN       PWR,NSHUT,MON
0/6/CPU0        A9K-SIP-700               IOS XR RUN       PWR,NSHUT,MON
0/6/0           SPA-2XOC48POS/RPR         OK               PWR,NSHUT,MON
0/6/1           SPA-OC192POS-XFP          OK               PWR,NSHUT,MON
0/6/2           SPA-1XCHSTM1/OC3          OK               PWR,NSHUT,MON
0/7/CPU0        A9K-MOD80-SE              IOS XR RUN       PWR,NSHUT,MON
0/7/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/7/1           A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
0 - left
1- right
ports start from 0 and LC numbers are from 0 so that would be Te0/0/0/0
First LC is 0, 2nd module would 1 so that would be Gi0/0/1/0
/A
