ASR9010 replacing PEM v1 to v3
spitfire
Hello everyone.
Our customer plan to upgrade power supply on ASR9010 from
1) v1 DC (A9K-2KW-DC, VID: V01) to v3 DC (A9K-DC-PEM-V3 + PWR-4.4KW-DC-V3)
2) v1 DC (A9K-2KW-DC, VID: V01) to v3 AC (A9K-AC-PEM-V3 + PWR-6KW-AC-V3)
I can’t clearly understand replacing procedure.
https://www.cisco.com/c/en/us/td/docs/iosxr/asr9000/hardware-install/hig/b-asr9k-hardware-installation-guide/b-asr9k-hardware-installation-guide_chapter_0101.html#task_1323197
For 1) in cli
#run
# pwrmod_change
In step 3 I don’t see “DC power supply version 3, fits …”For 2) In step 3 I don’t see “AC power supply version 3, fits …”How correctly replace power supply?
nkarpysh
Good Day,
Thanks for checking. It seems the output in the doc is truncated. You will see following on the router itself:
1)      AC power supply version 1, fits 3 across in single power shelf
2)      DC power supply version 1, fits 3 across in single power shelf
3)      AC power supply version 2, fits 4 across in single power shelf
4)      DC power supply version 2, fits 4 across in single power shelf
5)      AC power supply version 3, fits 3 across in single power shelf
6)      DC power supply version 3, fits 4 across in single power shelf
I created DDTS CSCvj56819 to fix the doc.
Niko
HTH,
Niko
nkarpysh
Good Day,
Niko
HTH,
Niko
