ASR9010 temperature
hi,
what is cisco recommended temperature for ASR 9010
RP/0/RSP0/CPU0:9010#show environment temperatures
Sun Oct  7 14:48:34.853 KSA
R/S/I   Modules Sensor                  (deg C)
0/0/*
        host    Inlet0                  35.5
        host    Hotspot0                61.3
0/1/*
        host    Inlet0                  42.3
        host    Hotspot0                72.0
0/2/*
        host    Inlet0                  41.0
        host    Hotspot0                78.1
0/RSP0/*
        host    Inlet0                  27.7
        host    Hotspot0                45.6
0/RSP1/*
        host    Inlet0                  28.1
        host    Hotspot0                44.5
Best Regards
Tahir
2 Accepted Solutions
Hi Tahir,
Vadim actually covered it really well in this thread
https://supportforums.cisco.com/thread/2132426
To paraphrase
The inlet temperature is closer to the fans and hence will show a cooler temperature. The hotspot is just that, the hottest point on the card. It is better to monitor the hotspot.
For your cards you are above the nominal and short-term operating values. This can be due to many reasons. Some devices are front-to-back cooling while others are side-to-side. Actual cooling of the environment along with the temperature of the air that is brought into the ASR9K. Fiber, copper, power cables etc that may be in the way can also affect cooling.
Not addressing the cooling concerns will not only show environmental messages in your console but can also cause damage to your cards.
HTH,
Sam
Temperature threshold are hard coded.
Router will generate alarms when MINOR/MAJOR/CRITICAL are reached.
For a Hotspot, critical error is at 86 degrees, and card shuts down at 90 (LC) / 93 (RSP).
78 looks a bit high to me, the router is most likely generating minor or major errors about it.
Make sure that:
- all slots have at least a blank cover (no empty slots)
- air filters are clean
- air intake is not obstructed by external objets
- room temperature is not too high
Max
smilstea
Hi Thair,
For LC's
Operating temperature (nominal) 41 to 104ºF (5 to 40ºC)
Operating temperature (short-term) 23 to 131ºF (-5 to 55ºC)
Operating humidity (nominal) relative humidity 10 to 85%
Storage temperature -40 to 158ºF (-40 to 70ºC)
Storage relative humidity 5 to 95%
For RSP
Operating temperature: 32 to 104°F (0 to 40°C)
Storage temperature: -40 to 167°F (-40 to 75°C)
Relative humidity: 10 to 90%, noncondensing
There are also recommendations for SFP's and other system components.
Sam
thanks sam,
Please exaplain me
what is Inlet temp         35.5
what is Hotspot temp        61.3
in my case what is recommend Inlet and Hotspot temperature for asr9k
regards
tahir
Hi Tahir,
To paraphrase
HTH,
Sam
Make sure that:
Max
