01-15-2022 12:58 AM
Hi All,
Cisco agent help me to borrow a ASR9901 chassis for evaluation purpose, and there is no BNG license installed,but i found there is some commands which can not support.
My question is, if I need a full functions of BNG in ASR9901, Does it need install evaluation license or permernanent licese?
Thanks.
Solved! Go to Solution.
01-15-2022 04:47 AM
You can configure the bng features without a license.
the router will alarm and produce messages stating it is out of compliance.
for testing purposes it would be ok, but eventually you will need to have the router registered and licensed
thanks
01-15-2022 04:47 AM
thanks
01-17-2022 07:27 PM
Hi tkarnani,
Thanks for quick response, We will try more command after we get the physical device, before we are using remote desktop to configure the ASR9901.
Is there any difference in BNG feature between ASR9901 and ASR9904, or between ASR9901 and XRV9000, We found that some BNG related configuration commands can not support in ASR9901. Is there any limitation in ASR9901 with XR-iOS in BNG feature comparing to ASR9904?
the XR IOS version of ASR9901 is 7.4.1, you can reference below snapshoot.
Tiger
