06-30-2014 06:34 PM
Hi All,
Apologies if this has already been asked but I want to know if there is a way to view access-list counters when it is used in a class-map and the policy-map is applied to an interface.
I tried the following command but I get "unrecognized location".
RP/0/RSP0/CPU0:R1# show access-lists ipv4 ACL-NETWORK-CONTROL-00001 hardware egress location 0/0/1
Tue Jul 1 01:24:20.077 UTC
Unrecognized location
RP/0/RSP0/CPU0:R1# show platform
Tue Jul 1 01:32:32.358 UTC
Node Type State Config State
0/RSP0/CPU0 ASR9001-RP(Active) IOS XR RUN PWR,NSHUT,MON
0/0/CPU0 ASR9001-LC IOS XR RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-20X1GE OK PWR,NSHUT,MON
0/0/1 A9K-MPA-4X10GE OK PWR,NSHUT,MON
IOS-XR version 4.2.3 on ASR9001.
Amit.
07-09-2014 09:31 AM
Hi Amit,
Since you are using access-list in a service policy applied to an interface.
Are you not seeing matches when you do "show policy-map interface g0/0/1/x in/out ?
In order to see the "show access-list" output you have to apply the acl in/out to the interface.
Best Regards,
Bheem
07-13-2014 09:15 PM
try this command and see if it works...
show access-lists ipv4 ACL-NETWORK-CONTROL-00001 hardware egress location 0/0/CPU0
05-30-2017 02:42 AM
Hi Amit,
Please share the interface configuration. If access group configured in interface, use below command format.
To display the hardware counters for a given access group, use the show access-lists ipv4 [access-list-name hardware {ingress | egress} [interface type interface-path-id] {location node-id}] command in EXEC mode.
S Mohammed Abdul Hafiz
