ASR9K Layer2
Hamza_MX
Hello ,
I want to pass Layer 2 connection acroos an ASR9K but it is not working .
Find below architecture and config :
----Layer2ASR9K.png                   ---------------csr---------------
interface GigabitEthernet1
no ip address
negotiation auto
interface GigabitEthernet1.10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet1.20
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
interface GigabitEthernet2
no ip address
shutdown
negotiation auto
interface GigabitEthernet3
no ip address
shutdown
negotiation auto
interface GigabitEthernet4
no ip address
shutdown
negotiation auto
router bgp 65001
bgp log-neighbor-changes
neighbor 10.10.10.2 remote-as 65002
address-family ipv4
neighbor 10.10.10.2 activate
neighbor 10.10.10.2 soft-reconfiguration inbound
exit-address-family
-----------------xrv1--------------
interface GigabitEthernet0/0/0/0.10
ipv4 address 10.10.10.2 255.255.255.0
encapsulation dot1q 10
interface GigabitEthernet0/0/0/0.20 l2transport
encapsulation dot1q 20
rewrite ingress tag pop 1 symmetric
interface GigabitEthernet0/0/0/1.20 l2transport
interface GigabitEthernet0/0/0/2
shutdown
router bgp 65002
bgp router-id 10.10.10.2
address-family ipv4 unicast
neighbor 10.10.10.1
remote-as 65001
soft-reconfiguration inbound always
l2vpn
bridge group BG20
bridge-domain 20
----xrv2--------
ipv4 address 10.10.20.2 255.255.255.0
ping between 10.10.20.2 and 0.10.20.1 dont work
Hamza_MX
Hello ,
It worked with the configuration below :
l2vpn
xconnect group FO
p2p FO1
show l2vpn bridge-domain group NAME bd-name NAME
please share the output for above command.
Did you create the respective vlan on each device?
csr - vlan 10 and 20
xrv1 - vlan 10
xrv2 - vlan 20
If yes, can you check the spanning tree?
Hamza_MX
Hello ,
l2vpn
xconnect group FO
p2p FO1
