bandwidth limitation on outgoing strict-priority queue on NCS540, IOS-XR 7.0.2
MalteHahlbeck
How do I configure bandwidth limitation on outgoing strict-priority queue on NCS540, IOS-XR 7.0.2?
Excerpt of my qos-configuration:
class-map match-any CLASS_VOICE
match traffic-class 5
end-class-map
policy-map EGRESS_QoS
class CLASS_VOICE
priority level 1
 police rate percent 10
class CLASS_VOICE-SIG
bandwidth remaining percent 3
 class CLASS_VIDEO
  bandwidth remaining percent 20
 class CLASS_DATA
  bandwidth remaining percent 50
 class CLASS_LOW
  bandwidth remaining percent 10
 class CLASS_NETWORK
 class class-default
end-policy-map
policy-map EGRESS_ SHAPING_PE
class class-default
service-policy EGRESS_QoS
shape average percent 100
end-policy-map
Applying to the interface and commit change:
service-policy output EGRESS_SHAPING_PE
!!% 'DPA_QOSEA' detected the 'warning' condition 'Unsupported action type for egress'
 So, egress policing is not allowed.
 In IOS-XE 16.x.x (ASR907) I can apply the following (working) policy-map with outgoing shaping as above:
class CLASS_VOICE
priority percent 10
class CLASS_VIDEO
class CLASS_DATA
class CLASS_LOW
class CLASS_NETWORK
class class-default
How can I archive a percentive bandwidth limitation on the priority queue? We need this feature to avoid starvation of non-priority-classes in case of congestion.
Malte
5 Replies 5
smilstea
Yes, that's true. But look at my example regarding IOS-XE. In IOS-XR there is no implicit policier at LLQ-level (as it is in IOS-XE). My question was: how can I archive this?
You can apply a shaper in the parent and child classes, that would be the most accurate and restrictive measure.
This is what I have seen other customers do with their priority queues. And then bandwidth statements for the queues without priority statements.
Sam
OK, thank you.
I will give it a try in our hard-ware lab. It seems to be a solution, what I have read so far. I will update this thread.
Malte
johnlloyd_13
Level 9
Level 9
hi,
i ran into the same problem in our NCS540 (IOS-XR).
i'm also trying to achieve the same QoS MQC with IOX-XE ASR especially for voice and apply 'priority percent'.
are we limited with 'shaping' in applying 'service-policy output'? will you be kind to share the config you end up using?
RP/0/RP0/CPU0:NCS540#sh run policy-map
Mon Mar 29 08:25:42.053 UTC
policy-map MPLS-OUT-v2
class MPLS-VOICE-v2
bandwidth percent 35
class MPLS-CLASS-7-v2
class MPLS-CLASS-6-v2
class MPLS-CLASS-4-v2
bandwidth remaining percent 40
class MPLS-CLASS-3-v2
class MPLS-CLASS-2-v2
class MPLS-CLASS-1-v2
class class-default
end-policy-map
EDIT - i just tried using 'priority' and 'shape average percent' but still getting a failed config error. can someone please advise how to achieve a similar MQC in IOS-XE as mentioned above by OP.
class MPLS-VOICE-v2
priority level 1
shape average percent 35
