BFD between ASR9001 and Palo Alto
Hi everybody, hope you are fine. I'm trying to implement BFD between two ASR9001 routers and a Palo Alto PA-5250 Firewall. I've configured BFD on the routers (under OSPF process)and the Firewall but they are not seeing each other, BFD sessions are not coming up. OSPF neighboring is OK, graceful restart works fine and when the cluster mastership changes everything goes smooth. Thing is that for broadcast segments if I ever loose a Cisco Router it will take 40 seconds for the OSPF process on the Firewall to detect this (dead timer 4xHello, There's a Nexus in the middle of the devices so interfaces link will not go down). This recovery time is not acceptable, is too high.
Has anyone tried to implement BFD between this vendors before? How did it go? Can you help me with the config please?
Another important information I think... there's a bundle Ethernet link on each of the ASR 9001 Routers. There's a port aggregation as well on each of the Firewalls (active/passive cluster). Could that interfere?
IOS-XR Version: Cisco IOS XR Software, Version 6.0.2[Default]
Palo Alto version: 8.0.9
Below you can find topology diagrams and config information.
Cheers,
Luis
Logical View
Physical
ASR Config
router ospf FIREWALL
 log adjacency changes detail
 bfd minimum-interval 300
 bfd multiplier 3
 vrf PROXY-TMP
  router-id 172.20.5.17
  address-family ipv4
  area 0
   interface Bundle-Ether1.1010
    bfd fast-detect
Thanks for the answer Aleksandar. The actual problem was that BFD was configured over a Bundle Interface so the following line had to be added to the configuration in order for that to work.
bfd
multipath include location 0/0/CPU0
Just for your info if you ever configure that check the command show bfd session detail, section MP DOWNLOAD STATE:
Cheers,
Luis
Aleksandar Vidakovic
Use "sh bfd session status detail ..." to see whether bfd process on asr9k is receiving any BFD packets from the peer. If yes, see "sh bfd session status history ..." to see why the session is kept down. Check whether any of the BFD specific NP counters are incrementing on the asr9k side. If yes, use "sh lpts pifib hardware static-police location ..." to see where are they punted (should be "Local", meaning line card CPU). If none of the BFD specific NP counters is incrementing, I would check the BFD packet format generated by the firewall to see whether there's anything suspicious.
For NP counter capture, see:
https://supportforums.cisco.com/t5/service-providers-documents/asr9000-xr-troubleshooting-packet-drops-and-understanding-np/ta-p/3126715
https://supportforums.cisco.com/t5/service-providers-documents/asr9000-xr-troubleshooting-packet-drops-drops-in-np-microcode/ta-p/3155145
For details of BFD implementation on asr9k see:
https://supportforums.cisco.com/docs/DOC-33907
/Aleksandar
bfd
Cheers,
Luis
