05-26-2022 05:56 PM
I'm discussing a new project for BNG-CGNAT and AAA for an ISP customer. Anyone could confirm which solution would fit better for GCN and AAA.
I was think in:
ASR9K- BNG
CPAR for - AAA/RADIUS
CGN?? - Which solution can replace the ISM CARD in ASR9K to support this feature?
RGR
Solved! Go to Solution.
05-29-2022 05:16 AM - edited 05-29-2022 05:22 AM
the VSM-500 replaces the ISM card
however the last day to order this card is Oct 2022
05-29-2022 11:25 PM
I would go with A10 for CGN. It is more feature rich and easier to scale.
There are many ISPs with A10 clusters (proprietary protocol for load-balancing, or you build it by yourself).
05-29-2022 09:24 AM
Hi, thanks for the information.
As far as I understood, the new design for the environment for GCN will be connected with Catalyst 8500-12X4Q.
05-29-2022 11:25 PM
05-30-2022 04:56 AM
Hi, thanks for the comments.
It should be the best scenario. ASR + A10
RGR
