Bundle Ethernet & ACL
Serpent2010
In ASR9K, I have a bundle-ether20 that has two physical ports as members  TenG1/1 & TenG1/2
The bundle-ether20 has two subinterfaces bundle-ether20.1 & bundle-ether20.2
I want to apply ACL on this connection
Q1) Shall this ACL be applied on the physical ports TenG1/1 & TenG1/2, or  bundle-ether20
Q2) Shall this ACL be applied on the subinterface ports bundle-ether20.1 & bundle-ether20.2, or  bundle-ether20
Many thanks
correct.
no need to apply it under the TenG and main interface.
any L3 port can apply RACL under it
so ACL will apply under subinterface.
Many thanks for the quick response, so in the context of my questions on bundle-ether20.1 & bundle-ether20.2 only
Neither bundle-ether20 nor TenG1/1 & TenG1/2, correct?
you need to add ACL to the below only to take effect.(as per the requirement you mentioned)
shall this ACL be applied on the subinterface ports bundle-ether20.1 & bundle-ether20.2,
BB
correct.
