11-05-2020 02:04 AM
Hi, I created a BVI interface but its not coming up
RP#show l2vpn bridge-domain detail
Thu Nov 5 02:46:14.610 UTC
Legend: pp = Partially Programmed.
Bridge group: vlans, bridge-domain: vlan100, id: 0, state: up, ShgId: 0, MSTi: 0
Coupled state: disabled
VINE state: BVI Resolved
MAC learning: enabled
MAC withdraw: enabled
MAC withdraw for Access PW: enabled
MAC withdraw sent on: bridge port up
MAC withdraw relaying (access to access): disabled
Flooding:
Broadcast & Multicast: enabled
Unknown unicast: enabled
MAC aging time: 300 s, Type: inactivity
MAC limit: 4000, Action: none, Notification: syslog
MAC limit reached: no, threshold: 75%
MAC port down flush: enabled
MAC Secure: disabled, Logging: disabled
Split Horizon Group: none
Dynamic ARP Inspection: disabled, Logging: disabled
IP Source Guard: disabled, Logging: disabled
DHCPv4 Snooping: disabled
DHCPv4 Snooping profile: none
IGMP Snooping: disabled
IGMP Snooping profile: none
MLD Snooping profile: none
Storm Control: disabled
Bridge MTU: 1500
MIB cvplsConfigIndex: 1
Filter MAC addresses:
P2MP PW: disabled
Create time: 04/11/2020 22:54:59 (03:51:15 ago)
No status change since creation
ACs: 4 (0 up), VFIs: 0, PWs: 0 (0 up), PBBs: 0 (0 up), VNIs: 0 (0 up)
List of ACs:
AC: BVI100, state is down (Segment-down)
Type Routed-Interface
MTU 1514; XC ID 0x80000003; interworking none
Error: Need at least 1 bridge port up
BVI MAC address:
00b8.b36e.980b
Split Horizon Group: Access
AC: Bundle-Ether3, state is unresolved
Flooding:
--More--
here is my L2VPN config
l2vpn
bridge group vlans
bridge-domain vlan100
interface Bundle-Ether3
interface TenGigE0/0/2/2
interface TenGigE0/0/0/0/1.100
routed interface BVI100
Solved! Go to Solution.
11-08-2020 11:22 PM
HI TKarnani,
I have modified my config to the below... Now the Bundle Ethernet and BVI doesnt come up
interface Bundle-Ether2
mtu 9216
interface Bundle-Ether2.999 l2transport
encapsulation dot1q 100
rewrite ingress tag pop 1 symmetric
l2vpn
bridge group 999
bridge-domain BD999
int Te0/0/0/30
Bundle id 2 mode active
Any ideas? I was expecting BVI and BE2 to come up once I have a member on BE2 (Te0/0/30) but it doesnt seem to work
11-05-2020 02:19 AM
can you provide more information, what is the device mode / version of code, how your network connected.
AC: Bundle-Ether3, state is unresolved - Looking at this error we are not able to figure out how this was configured and transport you using.
reference if you like to know more information as example :
11-05-2020 05:07 AM
BE3 is not significant. I just tried adding it, The interface that is important is nterface TenGigE0/0/0/0/1.100, this is not an NCS router, its a ASR9K
I am not sure what this error means
I thought as long as TenGige0/0/01.100 is up it should be good?
11-05-2020 06:08 AM
did you add l2transport on the configuration of your attachment circuits?
11-05-2020 06:28 AM
I just have this
interface TenGigE0/0/0/1.100 l2transport
11-05-2020 07:12 AM
is there a typo? in the config you have interface TenGigE0/0/0/0/1.100 << but you provided TenGigE0/0/0/1.100 << extra 0 in the bridge domain?
11-05-2020 07:42 AM
Yeah, I got it to work now, so now I can see BVI is up on both my ASK9k and NCS5500 but I am unable to ping the BVI addresses from one box to the other..
Also, how would I test this that vlan100 is being transported on this link?
thanks
11-05-2020 08:21 AM - edited 11-05-2020 08:21 AM
BVI does not understand vlans. so we will need to ensure that this command is under both physical interfaces "rewrite ingress tag pop 1 symmetric"
i would clear counters on both sides.
perform a ping with timeout 0
then check show interface for each physical interface to ensure we are sending out / receiving.
11-05-2020 04:41 PM
Hi Tkarnani,
I can't add that command on the physical interface since it has sub interfaces, I get the error below when I try it.
!!% Subinterface or Layer 2 configuration conflicts with existing configuration, or configuration in this commit: Cannot configure an interface as L2 when it has sub interfaces
11-08-2020 05:17 AM
Hi I was talking about the subinterfaces, not the main interfaces.
put "rewrite ingress tag pop 1 symmetric" on both sides
ping, check the counters on each interface to see if the pings are being sent out and received
11-08-2020 11:22 PM
HI TKarnani,
mtu 9216
l2vpn
bridge group 999
bridge-domain BD999
int Te0/0/0/30
