BVI interface not coming up
josephd2020
Hi, I created a BVI interface but its not coming up
RP#show l2vpn bridge-domain detail
Thu Nov 5 02:46:14.610 UTC
Legend: pp = Partially Programmed.
Bridge group: vlans, bridge-domain: vlan100, id: 0, state: up, ShgId: 0, MSTi: 0
Coupled state: disabled
VINE state: BVI Resolved
MAC learning: enabled
MAC withdraw: enabled
MAC withdraw for Access PW: enabled
MAC withdraw sent on: bridge port up
MAC withdraw relaying (access to access): disabled
Flooding:
Broadcast & Multicast: enabled
Unknown unicast: enabled
MAC aging time: 300 s, Type: inactivity
MAC limit: 4000, Action: none, Notification: syslog
MAC limit reached: no, threshold: 75%
MAC port down flush: enabled
MAC Secure: disabled, Logging: disabled
Split Horizon Group: none
Dynamic ARP Inspection: disabled, Logging: disabled
IP Source Guard: disabled, Logging: disabled
DHCPv4 Snooping: disabled
DHCPv4 Snooping profile: none
IGMP Snooping: disabled
IGMP Snooping profile: none
MLD Snooping profile: none
Storm Control: disabled
Bridge MTU: 1500
MIB cvplsConfigIndex: 1
Filter MAC addresses:
P2MP PW: disabled
Create time: 04/11/2020 22:54:59 (03:51:15 ago)
No status change since creation
ACs: 4 (0 up), VFIs: 0, PWs: 0 (0 up), PBBs: 0 (0 up), VNIs: 0 (0 up)
List of ACs:
AC: BVI100, state is down (Segment-down)
Type Routed-Interface
MTU 1514; XC ID 0x80000003; interworking none
Error: Need at least 1 bridge port up
BVI MAC address:
00b8.b36e.980b
Split Horizon Group: Access
AC: Bundle-Ether3, state is unresolved
Flooding:
--More--
here is my L2VPN config
l2vpn
bridge group vlans
bridge-domain vlan100
interface Bundle-Ether3
interface TenGigE0/0/2/2
interface TenGigE0/0/0/0/1.100
routed interface BVI100
HI TKarnani,
I have modified my config to the below... Now the Bundle Ethernet and BVI doesnt come up
interface Bundle-Ether2
mtu 9216
interface Bundle-Ether2.999 l2transport
encapsulation dot1q 100
rewrite ingress tag pop 1 symmetric
l2vpn
bridge group 999
bridge-domain BD999
int Te0/0/0/30
Bundle id 2 mode active
Any ideas? I was expecting BVI and BE2 to come up once I have a member on BE2 (Te0/0/30) but it doesnt seem to work
10 Replies 10
balaji.bandi
can you provide more information, what is the device mode / version of code, how your network connected.
AC: Bundle-Ether3, state is unresolved  - Looking at this error we are not able to figure out how this was configured and transport you using.
reference if you like to know more information as example :
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5000/vpn/60x/b-ncs5000-l2vpn-configuration-guide-60x/b-ncs5000-l2vpn-configuration-guide-60x_chapter_0100.html
BB
BE3 is not significant. I just tried adding it, The interface that is important is nterface TenGigE0/0/0/0/1.100, this is not an NCS router, its a ASR9K
I am not sure what this error means
I thought as long as TenGige0/0/01.100 is up it should be good?
did you add l2transport on the configuration of your attachment circuits?
I just have this
interface TenGigE0/0/0/1.100 l2transport
is there a typo? in the config you have interface TenGigE0/0/0/0/1.100  << but you provided TenGigE0/0/0/1.100 <<  extra 0 in the bridge domain?
Yeah, I got it to work now, so now I can see BVI is up on both my ASK9k and NCS5500 but I am unable to ping the BVI addresses from one box to the other..
Also, how would I test this that vlan100 is being transported on this link?
thanks
BVI does not understand vlans. so we will need to ensure that this command is under both physical interfaces "rewrite ingress tag pop 1 symmetric"
i would clear counters on both sides.
perform a ping with timeout 0
then check show interface for each physical interface to ensure we are sending out / receiving.
Hi Tkarnani,
I can't add that command on the physical interface since it has sub interfaces, I get the error below when I try it.
!!% Subinterface or Layer 2 configuration conflicts with existing configuration, or configuration in this commit: Cannot configure an interface as L2 when it has sub interfaces
Hi I was talking about the subinterfaces, not the main interfaces.
put "rewrite ingress tag pop 1 symmetric" on both sides
ping, check the counters on each interface to see if the pings are being sent out and received
HI TKarnani,
mtu 9216
l2vpn
bridge group 999
bridge-domain BD999
int Te0/0/0/30
