Can not enable ipv6 unicasting
I have cisco catalyst Model WS-C3560X-48, SW Version 15.0(1)SE2, SW Image C3560E-UNIVERSALK9-M
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3560X-48       15.0(1)SE2            C3560E-UNIVERSALK9-M
I want to enable ipv6 but I can't
Switch(config)#ip?
ip  ipc
I search on cisco Feature Navigator it tell that this image can support ipv6.
6 Replies 6
Ivan Krimmel
Level 7
Level 7
Have you enabled 'ipv6 unicast-routing' enabled in the global config mode?
Andre Gustavo Albuquerque
What is the sdm template you are using?
Try to follow the steps here
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_58_se/configuration/guide/swipv6.html#wp1059828
and report it back here if it fails.
HTH, Gustavo
Thank you for your reply and I can not open the link because of Forbidden.
I type the command ipv6 unicasting but it can not.
Wonderful, after i configure command
Switch(config)#sdm prefer dual-ipv4-and-ipv6 default
i can use IPv6 features.
Thank, Andre.
Why we need to configure this command for the switch?
Any special reason?
