CGN Configuration for BGP Router
ingot.marulam
Hi all,
I am in the middle of NAT configuration testing for new ASR9010 implementation. Customer need NAT feature and ordered ISM for the CGN. Need your help to check our configuration and the testing environtment, because we found this configuration didn't work with this testing environtment. The testing environtment is described below.
The configurations are:
vrf InsideUserNAT
address-family ipv4 unicast
vrf InsideWifiNAT
vrf InsideOfficeNAT
hw-module service cgn location 0/0/CPU0
interface GigabitEthernet0/1/1/0
description NAT Test 1
ipv4 address 10.1.9.129 255.255.255.0
transceiver permit pid all
interface GigabitEthernet0/1/1/1
description NAT Test 2
ipv4 address 100.62.16.5 255.255.255.252
interface ServiceApp1
description ASVI for InsideUserNAT
vrf InsideUserNAT
ipv4 address 1.1.1.1 255.255.255.252
service cgn cgn1 service-type nat44
interface ServiceApp2
description ASVI for OutsideUserNAT
ipv4 address 2.1.1.1 255.255.255.252
interface ServiceApp3
description ASVI for InsideOfficeNAT
vrf InsideOfficeNAT
ipv4 address 3.1.1.1 255.255.255.252
interface ServiceApp4
description ASVI for OutsideOfficeNAT
ipv4 address 4.1.1.1 255.255.255.252
interface ServiceApp5
description ASVI for InsideWifiNAT
vrf InsideWifiNAT
ipv4 address 5.1.1.1 255.255.255.252
interface ServiceApp6
description ASVI for OutsideWifiNAT
ipv4 address 6.1.1.1 255.255.255.252
interface ServiceInfra1
ipv4 address 100.10.10.1 255.255.255.252
service-location 0/0/CPU0
router static
  100.62.16.0/22 Null0 210
  100.62.16.0/24 ServiceApp2
  100.62.17.0/24 ServiceApp4
  100.62.18.0/24 ServiceApp6
vrf InsideUserNAT
   0.0.0.0/0 ServiceApp1
   10.1.9.0/24 GigabitEthernet0/1/1/0 10.1.9.130
vrf InsideWifiNAT
   0.0.0.0/0 ServiceApp5
vrf InsideOfficeNAT
   0.0.0.0/0 ServiceApp3
service cgn cgn1
service-location preferred-active 0/0/CPU0
service-type nat44 nat1
  inside-vrf InsideUserNAT
   map ip one-to-one
   map address-pool 100.62.16.0/24
  inside-vrf InsideWifiNAT
   map address-pool 100.62.17.0/24
  inside-vrf InsideOfficeNAT
   map address-pool 100.62.18.0/24
  protocol udp
   session active timeout 20
end
RP/0/RSP0/CPU0:BGP-NAT#term leng 24
Wed Jul 10 00:08:35.907 UTC
We can reach internet ip address from GigabitEthernet0/1/1/1. ServiceInfra interface and all serviceapp interfaces are up. Need help check this issue because we will do migration by the end of this week.
Thanks in advance and really appreciate your help.
20 Replies 20
Hi Ingot,
ABF config looks right (one comment, remember that ABF only works for IPv4 traffic, not MPLS, so as long as you receive packets unlabelled, it will work fine).
performance-wise, no particular config is needed and the CGN solution is deployed in many customers without any noticeable impact for final users (the latency induced by the system is absolutely minimal).
Usually, the perf issues are seen when you have MTU issues or load balancing issues (hence my suggestion to try only with one peering interface instead of three).
Since you control the host, I suggest you install wireshark on it and capture traffic, you will probably find what's going on exactly,
Kind regards,
N.
Hi Nicolas,
Just found the cause of browsing experience problem. There is an issue with ISM module that cause ISM couldn't save the CGN Configuration. I am openning this issue to the TAC. Right now we are waiting for the TAC engineer about this.
Just curious, does CGN support static 1 to 1 NAT maping? Because the customer need the static 1 to 1 mapping, if you have the configuration guide or document related, appreciate if you can share me.
Thanks guys for your help.
Hi Ingot,
yes 1to1 is available in ISM since 4.2.3 (and you configured it at some point in the configs you shared in this thread).
To quote the feature description:
"The default behavior in the NAT44 translation is many-to-one i.e, multiple private IP addresses can be mapped to a single public IP address. The one-to-one IP translation feature will ensure every public IP address will be mapped to one and only private IP address. However, ports are not restricted. It is enforceable on an inside-vrf basis i.e, it will have to be explicitly configured for each inside-vrf."
Cheers,
N.
Hi Nicolas,
Sorry, what I mean is Static 1 to 1 NAT. I checked with cisco team already, and they said still on the road map.
But you were right, I configured 1 to 1 maping, thanks for the explanation Nicolas. I really appreciate that.
Cheers,
Ingot.
budilasmono
Hi All,
We want to ask about ISM scalability issue. The issue are :
1. Each ISM handling 14Gbps of NAT translation.
2. We want to install 6 ISM module to handle 80Gbps NAT traffic from subs.
3. We only have one big bundled interface on the ASR router to the subscriber.
the diagram :
subscriber --- (gateway router) --- (ASR NAT router) --- internet
each link is 80Gig traffic.
(The gateway router) send all 0.0.0.0/0 traffic to (ASR NAT router)
(The gateway router) have bundled-ether(8 TenGElink) interface to (ASR NAT router)
(The gateway router) doesn't have capability to sort/classify/choose which customer ip goes to which interface to internet because of 0.0.0.0/0 to (ASR NAT router)
What is the solution for this, so that (ASR NAT router) can :
1. Can utilize all the ISM prefered active module for all subs.
2. Can have only one big insidevrf assigned to bundle-ether (8 TenGE link). And this one big insidevrf applied to all 6 ISM module.
3. Can use the same insidevrf name for each of all servicecgn that assigned to each of all 6 ISM module.
4. Can use different insidevrf name for each of 6 ISM servicecgn. But the different insidevrf share the same private IP pool from bundle-ether, but different public map pool. (because gateway router only sending 0.0.0.0/0 to ASR NAT and cannot do which subs pool goes to which interface to ASR NAT using route-map/set next hop).
5. Can the ISM module be bundled in one servicecgn. And all NAT process is spreading accross 6 module, and from customer via gateway with default gateway without doing the ACL to specify source of customer pool go to specific interface to get associated with unique vrf that get assigned to specific which ISM doing the nat work. But instead one big bundled of 6 ISM to 1 ISM processing NAT.
Please help.
Budi L
Hi Budi,
please use the thread
https://supportforums.cisco.com/message/4022965
for this discussion,
N.
