07-21-2012 09:24 PM
Recently we have purchased Cisco ASR 9010 router. We have setup a 1Gbps copper based SFP module in the line card. It detect the module and I have found this by using show controller. But when I coonect a RJ-45 cable between thre router and my laptop, port do not up, even I connect the cable to a cisco switch that time also it is not working. Is there any command to up this port!
Please help.
Shuvo
02-20-2018 06:14 AM
Ciao Niko thanks for your feedbacks so far.
Consider we are speaking about copper ports (SFP-T) and we have 4 different connection to 4 different ports , all do not come up .On remote side there aren't SFPs , there are C3750 (copper ports).
Cabling team is saying cables are ok.
All things lead me to think there is something to investigate on ASR9010 side but i have no more arrows , all suggested commands have been put under interface conf. Without success.
Any idea?
02-20-2018 06:39 AM
Thanks Riccardo,
Unfortunately within this forum we cant do extensive verification thus TAC case is beneficial for through analysis and fast resolution.
From what I also see is that negotiation does not seem to happen with other side:
Link Partner Autoneg Speed/Duplex: invalid
And as you've shown before autonegotiation is configured on ASR9k side. So we can try disabling it and specifying the speed manually:
- no neg auto
- speed 1000
Check also config on the other side and try forcing link to speed and duplex manually.
Try moving SFP to other ports to see if working fine there. Please also mention what kind of ASR9k/card an IOS-XR version we are talking about.
Niko
02-21-2018 12:16 AM
Niko , i have solved, it Was a cabling issue. Thanks for your support
04-16-2018 01:17 AM
The 24x10 supports some copper:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
As for tweaking the OS there are the standard hidden unsupported transceiver commands but those are best effort.
