Cisco ASR 9010 Copper port problem
mostakimulhuq
Recently we have purchased Cisco ASR 9010 router. We have setup a 1Gbps copper based SFP module in the line card. It detect the module and I have found this by using show controller. But when I coonect a RJ-45 cable between thre router and my laptop, port do not up, even I connect the cable to a cisco switch that time also it is not working. Is there any command to up this port!
Please help.
Shuvo
18 Replies 18
Leo Laohoo
Your laptop has a triple-speed (10/100/1000BaseTx) NIC card?
robyn.byrne
What model SFP are you using ? as I believe it needs to be SFP-GE-T.
RJ
try enabling autonegociation with:
no duplex
no speed
on the switch side try:
duplex full
if the SPF is ok it should come up.
jstuxuhu0816
Do you need to use the media-type command?
charlhug
You likely need "negotiation auto" configured under this port, as many devices have autonegotiation enabled by default but the ASR9000 does not. The "media-type" command is not present on the ASR9000 as it's used to switch between SFPs and fixed copper ports - not for copper SFPs.
For the "Negotiation auto", do you mean for 1000M interface, since the 10G interface is alwasy force-up.
Try to configure this command under the interface :
"transceiver permit pid all"
mostakimulhuq
Thank Michalis.
I have applied your command and it is working.
Thanks very much for your co-operation.
Shuvo
hi , i have same problem with 1G ports on my asr9010 , both with SFP-T transc and with 1000BASE-SX SFP
Pls check following link about transceivers support:
https://supportforums.cisco.com/t5/service-providers-blogs/asr9000-policy-3rd-party-optics/ba-p/3106940
Niko
HTH,
Niko
i'm not able to bring up 1gb copper ports on my asr9010 , linecard is A9K-40GE-TR SFP type is SFP-GE-T . i did put the following commands under every interfaces:
negotiation auto
service unsupported-transceiver
without success. Can somebody help me?
Hi Riccardo,
The best way is to open the TAC case to verify it in detail. Here we can check basics if you provide output of
show pfm loc all
"show controller Gig... all" -- put the correct port number
show log
Have you also made sure that there are no L1 issues on the line itself? Does the interface come with loopback internal?
Niko
HTH,
Niko
Hello , here attached the show commands required.
Hi RIccardo,
Thanks for the logs. I see that SFP is supported by the system so problem is different from what is discussed above:
Pluggable Compl.    : (Service Un) - Compliant
Pluggable Type Supp.: (Service Un) - Supported
Pluggable PID Supp. : (Permit All) - Supported
We can see that link stays down as no incoming signal detected:
H/W Link Defects    : (0x0000000000000038)  HW_LINK SFP_PHY_LINK LASI  ------ loss of signal
Also supported by this:
"Down (Reason: Link loss or low light"
This can identify the problem on:
- cable
- remote side
- transceiver itself
Best course of action will be:
- Open TAC case to verify it
- check cable
- Try to use any other know good transceiver in same port
- Try to use any other know good transceiver on remote side
- Change port on either side of this link
Niko
HTH,
Niko
