Cisco BNG Geo-Redudancy on ASR9001
mhd_rabbani24
Good day Everyone!
Currently my customer wants to do clustering active-active on 2 chassis of ASR9001 (IOS XR 6.1.3), at first i found that nV Edge System is suitable for their needs but turns out this technology is already discontinued after IOS XR 5.3.x
So i managed to open case to Cisco Virtual Engineering to find out, they said that it is recommended to migrate to BNG Geo-Redudancy, but i can't find specific document about the prerequisite of this technology
i.e : nV Edge System prerequisites :
  • 2 x Cisco ASR 9001
  • 2 x 10G link (for IRL) with fiber cables
  • 2 x 1G link (for Cluster/Control Links) with fiber/copper cables
  • ASR 9000 NV Cluster License A9K-NV-CLUSTR-LIC(=)
  • IOS XR 4.2.x or later
Can you guys show me what is the prerequisites for BNG Geo-Redudancy? to be honest, this new kinda thing for me :(
Very appreciate for your help! :)
Cheers,
Bani
Aleksandar Vidakovic
hi Bani,
you will find plenty of good information here: https://supportforums.cisco.com/document/12981676/asr9000xr-using-and-understanding-bng-geo-redundancy
hth,
/Aleksandar
Hi Aleksandar,
very appreciated with your reply!
is Geo-Redudancy technology requires specific license? just to make sure, because currently this is a new project for my client :)
Bani
Hi Bani,
These are the software license PIDs for BNG:
• S-A9K-BNG-LIC-8K —for non-geo redundancy sessions
• S-A9K-BNG-ADV-8K —for geo redundancy sessions
Please refer (https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/bng/configuration/guide/b-bng-cg-asr9k-61x.pdf) for more details.
Vishal
Geo redundancy is a powerful new technology for XR BNG that allows for session synchronization between 2 nodes. This means that a session active on one node has a shadow and fully programmed session on a standby node, so that when the active chassis fails, the standby BNG can take over and continue to forward the session info WITHOUT service interruption to the user.
Geo redundancy overcomes some of the restrictions that other redundancy models have which makes it a solution that is very compelling.
please check below link for more details:-
https://supportforums.cisco.com/t5/service-providers-documents/asr9000-xr-using-and-understanding-bng-geo-redundancy/ta-p/3158636
