11-10-2016 09:01 PM
Hi Team,
Do you know the router in cisco which should support 4X 10G Ethernet (RJ-45), I had gone thru the ASA 1001H-X series, unfortunately it only supports 10G SFP.
Your response is highly appreciated.
Saurabh
11-10-2016 10:17 PM
Either the ASR 1001HX or ASR 1002HX.
11-10-2016 10:30 PM
Hi Leo,
Appreciate your early response, Could you please provide the PID of the module/slot/convertor by which I can use 10G Ethernet (RJ-45). I can’t see with ASR 1001HX or ASR 1002HX any RJ-45 based 10G option available.
Saurabh
11-27-2016 11:14 AM
Unfortunately, ASRs don't support RJ45 10GE interfaces. Also, there are no SFP+ interfaces supporting 10GBaseT.
If You need to have the 10GBaseT interface, you can try to use 6500E/6800 linecards or Nexus 3000/5000 series - they have routing capabilities, but YMMV - depends on what you need this router for.
05-07-2018 12:26 AM
The Cisco Catalyst 3850 Series Switches support full IEEE 802.3at Power over Ethernet Plus (PoE+), Cisco
Universal Power Over Ethernet (Cisco UPOE®
), modular and field-replaceable network modules, RJ-45 and fiberbased
downlink interfaces, and redundant fans and power supplies.
● Integrated wireless controller capability with:
◦ Up to 40G of wireless capacity per switch (48-port RJ45 models)
◦ Support for up to 100 access points and 2000 wireless clients on each switching entity (switch or stack)
● 24 and 48 10/100/1000Mbps data PoE+ and Cisco UPOE models with Energy-Efficient Ethernet (EEE)
● 24 and 48 100Mbps/1/2.5/5/10 Gbps Cisco UPOE models with Energy-Efficient Ethernet (EEE)
● 12- and 24-port 1 Gigabit Ethernet SFP-based models
● 12- and 24-port 1/10 Gigabit Ethernet SFP+-based models
● 48-port 1/10 Gigabit Ethernet SFP+ model with 4 fixed 40 Gigabit Ethernet QSFP+ uplinks
● Cisco StackWise-480 technology provides scalability and resiliency with 480 Gbps of stack throughput1
● Cisco StackPower®
technology provides power stacking among stack members for power redundancy1
● Five optional uplink modules2 with 4 x Gigabit Ethernet, 2 x 10 Gigabit Ethernet, 4 x 10 Gigabit Ethernet3
8 x 10 Gigabit Ethernet4, or 2 x 40 Gigabit Ethernet QSFP+4
ports
● Dual redundant, modular power supplies and three modular fans providing redundancy
● Full IEEE 802.3at (PoE+) with 30W power on all copper ports in 1 Rack Unit (RU) form factor
● Cisco UPOE with 60W power per port in 1 Rack Unit (RU) form factor
● IEEE 802.3bz (2.5/5 G/s BASE-T) to go beyond 1 Gb/s with existing Cat5e and Cat6
● IEEE 802.1ba AV Bridging (AVB) built-in to provide better AV experience for including improved time
synchronization and QoS
● Software support for IPv4 and IPv6 routing, multicast routing, modular Quality of Service (QoS), Flexible
NetFlow (FNF), and enhanced security features
● Single universal Cisco IOS® Software image across all license levels, providing an easy upgrade path for
software features
● Cisco DNA services delivered through Cisco ONE™ Software, providing simplified, high-value solutions with
license portability and flexibility
● Support for AES-256 with the powerful MACSEC 256-bit for SFP+ and Multigigabit models and 128-bit
encryption algorithm available on all models
