XR policing, exceed vs violate?
Seth Beauchamp
With XR, if you have a policy-map configured with a class like below... at what point is traffic considered "exceed" vs "violate"? without PIR specifically configured, does it assume a default PIR?
class EF
priority level 1
police rate percent 80
conform-action transmit
exceed-action transmit
violate-action drop
tkarnani
I have configured your policy on a lab node, you can verify values with below command
RP/0/RSP0/CPU0:ASR9006-M#show qos interface tenGigE 0/2/1/3 input
Thu May 10 05:03:02.168 EDT
Interface: TenGigE0_2_1_3 input
Bandwidth configured: 10000000 kbps Bandwidth programed: 10000000 kbps
ANCP user configured: 0 kbps ANCP programed in HW: 0 kbps
Port Shaper programed in HW: 0 kbps
Policy: EFFF Total number of classes: 2
Level: 0 Policy: EFFF Class: EF
QueueID: 196640 (Port Priority 1)
Policer Profile: 64 (SrTCM)
Conform: 8000000 kbps (80 percent) Burst: 100000000 bytes (0 Default)
Peak Burst: 100000000 bytes (0 Default)
Child Policer Conform: TX
Child Policer Exceed: TX
Child Policer Violate: DROP
Level: 0 Policy: EFFF Class: class-default
QueueID: 196642 (Port Default)
policy-map EFFF
 class EF
  priority level 1
   violate-action drop
 class class-default
 end-policy-map
tkarnani
policy-map EFFF
 class EF
  priority level 1
   violate-action drop
 class class-default
 end-policy-map
Ah i see. Thanks.
If you use it as an output policy, does yours show the Burst as well? Mine doesn't show the same when i run the command with "output" instead.
EDIT: oops sorry, it does indeed show it. i was using the wrong command.
Hi Seth,
here is what i see
RP/0/RSP0/CPU0:ASR9006-M#show qos interface tenGigE 0/2/1/3 output
Thu May 10 05:37:40.385 EDT
Interface: TenGigE0_2_1_3 output
QueueID: 201800 (Priority 1)
Queue Limit: 98304 kbytes Abs-Index: 173 Template: 0 Curve: 6
Shape CIR Profile: INVALID
QueueID: 201802 (Priority Normal)
Queue Limit: 24512 kbytes Abs-Index: 142 Template: 0 Curve: 0
WFQ Profile: 3/9 Committed Weight: 10 Excess Weight: 10
Bandwidth: 0 kbps, BW sum for Level 0: 0 kbps, Excess Ratio: 1
