Cisco Router with 10G RJ-45 Ethernet
Saurabh K verma
Hi Team,
Do you know the router in cisco which should support 4X 10G Ethernet (RJ-45), I had gone thru the ASA 1001H-X series, unfortunately it only supports 10G SFP.
Your response is highly appreciated.
Saurabh
Leo Laohoo
Either the ASR 1001HX or ASR 1002HX.
Hi Leo,
Appreciate your early response, Could you please provide the PID of the module/slot/convertor by which I can use 10G Ethernet (RJ-45). I can’t see with ASR 1001HX or ASR 1002HX any RJ-45 based 10G option available.
Saurabh
Unfortunately, ASRs don't support RJ45 10GE interfaces. Also, there are no SFP+ interfaces supporting 10GBaseT.
If You need to have the 10GBaseT interface, you can try to use 6500E/6800 linecards or Nexus 3000/5000 series - they have routing capabilities, but YMMV - depends on what you need this router for.
The Cisco Catalyst 3850 Series Switches support full IEEE 802.3at Power over Ethernet Plus (PoE+), Cisco
Universal Power Over Ethernet (Cisco UPOE®
), modular and field-replaceable network modules, RJ-45 and fiberbased
downlink interfaces, and redundant fans and power supplies.
● Integrated wireless controller capability with:
◦ Up to 40G of wireless capacity per switch (48-port RJ45 models)
◦ Support for up to 100 access points and 2000 wireless clients on each switching entity (switch or stack)
● 24 and 48 10/100/1000Mbps data PoE+ and Cisco UPOE models with Energy-Efficient Ethernet (EEE)
● 24 and 48 100Mbps/1/2.5/5/10 Gbps Cisco UPOE models with Energy-Efficient Ethernet (EEE)
● 12- and 24-port 1 Gigabit Ethernet SFP-based models
● 12- and 24-port 1/10 Gigabit Ethernet SFP+-based models
● 48-port 1/10 Gigabit Ethernet SFP+ model with 4 fixed 40 Gigabit Ethernet QSFP+ uplinks
● Cisco StackWise-480 technology provides scalability and resiliency with 480 Gbps of stack throughput1
● Cisco StackPower®
technology provides power stacking among stack members for power redundancy1
● Five optional uplink modules2 with 4 x Gigabit Ethernet, 2 x 10 Gigabit Ethernet, 4 x 10 Gigabit Ethernet3
8 x 10 Gigabit Ethernet4, or 2 x 40 Gigabit Ethernet QSFP+4
ports
● Dual redundant, modular power supplies and three modular fans providing redundancy
● Full IEEE 802.3at (PoE+) with 30W power on all copper ports in 1 Rack Unit (RU) form factor
● Cisco UPOE with 60W power per port in 1 Rack Unit (RU) form factor
● IEEE 802.3bz (2.5/5 G/s BASE-T) to go beyond 1 Gb/s with existing Cat5e and Cat6
● IEEE 802.1ba AV Bridging (AVB) built-in to provide better AV experience for including improved time
synchronization and QoS
● Software support for IPv4 and IPv6 routing, multicast routing, modular Quality of Service (QoS), Flexible
NetFlow (FNF), and enhanced security features
● Single universal Cisco IOS® Software image across all license levels, providing an easy upgrade path for
software features
● Cisco DNA services delivered through Cisco ONE™ Software, providing simplified, high-value solutions with
license portability and flexibility
● Support for AES-256 with the powerful MACSEC 256-bit for SFP+ and Multigigabit models and 128-bit
encryption algorithm available on all models
