Detailed guide on how to setup ASR9000 BNG for IPoE subscribers?
CSCO11865434
Can anyone guide me on how to setup BNG for IPoE subscribers correctly?
basically I did some basic configurations on connecting BNG to the radius, and the CPes to the BNG, everything looks fine for the PPPoE users, but I might have many question regarding how to authenticate users through their CPe's MAC address? how to put a rate limit for them? what kind of attribute should I use for IPoE subscribers.
what I'm doing now is just for a lab test in order to make things work for later.
Thank you.
xthuijs
Kawan, got some refs for you, either check my profile and pull the documents under my profile or go to google and search on: asr9000 bng deployment guide, there is a general guide and also a step by step instruction on how to set them up and even a training guide.
let me know if you can't find them and if that is what you're looking for.
https://supportforums.cisco.com/docs/DOC-23170
https://supportforums.cisco.com/docs/DOC-19702
https://supportforums.cisco.com/docs/DOC-19726
thanks
xander
xthuijs
thanks
xander
thank you Alexander for your replay.
actually I saw one of those links that you wrote and it really helps me but the other two I didn't saw them. I will try to read them after this weekend and see what can I do after.
thank you so much for helping
Hi Xander
Please let me know if i can ask you a specific question on this subject.
