09-08-2013 06:24 AM
Can anyone guide me on how to setup BNG for IPoE subscribers correctly?
basically I did some basic configurations on connecting BNG to the radius, and the CPes to the BNG, everything looks fine for the PPPoE users, but I might have many question regarding how to authenticate users through their CPe's MAC address? how to put a rate limit for them? what kind of attribute should I use for IPoE subscribers.
what I'm doing now is just for a lab test in order to make things work for later.
Thank you.
Solved! Go to Solution.
09-12-2013 12:02 PM
Kawan, got some refs for you, either check my profile and pull the documents under my profile or go to google and search on: asr9000 bng deployment guide, there is a general guide and also a step by step instruction on how to set them up and even a training guide.
let me know if you can't find them and if that is what you're looking for.
https://supportforums.cisco.com/docs/DOC-23170
https://supportforums.cisco.com/docs/DOC-19702
https://supportforums.cisco.com/docs/DOC-19726
thanks
xander
09-12-2013 12:02 PM
thanks
xander
09-13-2013 03:53 AM
thank you Alexander for your replay.
actually I saw one of those links that you wrote and it really helps me but the other two I didn't saw them. I will try to read them after this weekend and see what can I do after.
thank you so much for helping
07-05-2020 07:17 PM
Hi Xander
Please let me know if i can ask you a specific question on this subject.
