DHCP Server Configuration on ASR 9010 does not work
I have problem setting up the dhcp on the asr 9010 equipment.
My settings are as follows:
--> ASR 9010
interface GigabitEthernet0/0/0/1
description ***Conect to sw***
vrf client_Multiservicos
interface GigabitEthernet0/0/0/1.41
description === Dados ===
ipv4 address 10.51.23.254 255.255.255.0
encapsulation dot1q 41
interface GigabitEthernet0/0/0/1.60
description === Management ===
ipv4 address 10.51.5.254 255.255.255.0
encapsulation dot1q 60
pool vrf client_Multiservicos ipv4 Dados
 address-range 10.51.23.1 10.51.23.250
dhcp ipv4
 profile Dados server
  pool Dados
  allow-move
  dns-server 10.1.1.1 10.1.1.2
  domain-name test.local
  subnet-mask 255.255.255.0
  default-router 10.51.23.254
interface GigabitEthernet0/0/0/1.41 server profile Dados
--> Switch 3650
interface Ethernet0/0
description *** CONNECT ASR 9010 ***
switchport trunk allowed vlan 41,60
switchport mode trunk
interface Vlan60
description *** Managment ***
ip address 10.51.5.253 255.255.255.0
ip default-gateway 10.51.5.254
interface Ethernet0/1
description ***CONNECT PC***
switchport access vlan 41
switchport mode access
duplex auto
Pc does not catch ip by dhcp. But if I configure dhcp on switch 3650 it works. In this case I need to have dhcp server on asr 9010.
Attached the topology
Can you help me please?
5 Replies 5
Hi Jaderson Pessoa,
I tested it that way too but it didn't work unfortunately...
smilstea
You also need to assign the VRF to the DHCP profile.
Can you try that and then send the following outputs collected a few times:
show dhcp ipv4 server profile name <profile name>
show dhcp ipv4 server profile name <profile name> loc 0/0/cpu0
show dhcp ipv4 server statistic
show dhcp ipv4 server statistics loc 0/0/cpu0
show dhcp ipv4 server binding vrf <vrf name>
Sam
Hi smilstea,
I put the vrf inside the ipv4 dhcp and still does not work.
Attached information requested.
I don't see any packets coming in and reaching the server, will need to debug and see if they are dropping due to a specific reason or if we see any packets at all.
debug dhcp ipv4 packet filter-id interface <interface>
debug dhcp ipv4 server errors
debug dhcp ipv4 server events
debug dhcp ipv4 server internals
Sam
