DHCP Server within a VRF - ASR9K running 5.3.3
fbloss100
I would like to create a dhcp server within a vrf. I did read the DAPS Support document which does allow the user to configure an address range within a vrf but the other options like default router, DNS, etc are not there. Any help would be appreciated.
Borgenstrand
based on what I have read in:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-3/addr-serv/configuration/guide/b-ipaddr-cg53asr9k/b-ipaddr-cg53asr9k_chapter_0101.html#concept_CA2B956D03FB4533A3653BD0119AC788
I think you should be able to do it. If you try to do it, is there any missing commands or issues?
Borgenstrand
Hi Borgenstrand,
Thank you for your help. This was what I needed.
Fred
