Error with ASR-9001 running 5.3.1
nesttech1
We have an ASR-9001 unit that was upgraded from 5.1.3 to 5.3.1.  After the upgrade with the TURBOBOOT process, the following messages appear during the boot up:
2015-10-27 09:58:29 UTC 0/RSP0/CPU0 /zl30160_hal.c:265: (ERROR) zl30160_reg_write: I2C write fails for offset 0x7f reason: Input/output error
2015-10-27 09:58:29 UTC 0/RSP0/CPU0 /zl30160_init_setup.c:450: (ERROR) zl30160_rsp3_setup: zl30160_rsp3_dpll_setup() failure reason: Input/output error
2015-10-27 09:58:29 UTC 0/RSP0/CPU0 /zl30160_main.c:335: (ERROR) main: zl30160_initial_device_setup() failure reason: Input/output error
RP/0/RSP0/CPU0:Oct 27 09:58:31.918 : imio[64]: %PLATFORM-IMIO-3-OPERATION_NOTIFY : imio_main: cold start
Also, we do not see the standard "SYSTEM CONFIGURATION IN PROCESS" message.
When the system completes the boot up, the "sh platform" command shows that everything is working OK
However, we we run the "sh diagnostic result" command, we get the message that the node is not running as below:
RP/0/RSP0/CPU0:ios(admin)#sh diagn res loc all
Tue Oct 27 10:35:35.255 UTC
Diagnostic[loc/sub_loc: 1/-1]: Diag get data error: no diag process running for the node or the node is not up.
ASR9001-LC 0/0/CPU0:
  Overall diagnostic result: PASS
  Diagnostic level at card bootup: bypass
  Test results: (. = Pass, F = Fail, U = Untested)
  1  ) LcEobcHeartbeat -----------------> .
  2  ) FIAScratchRegister --------------> .
  3  ) BWScratchRegister ---------------> .
  4  ) WLScratchRegister ---------------> .
  5  ) NPULoopback ---------------------> .
Please let me know any suggestions.  Thank you.
I recommend consultung the bug database before posting questions to the forum, took me 2 seconds to find out that your first errors are a cosmetic issue:
https://tools.cisco.com/bugsearch/bug/CSCtz68435
Regarding the diag error though I did not find anything, might be a new bug. In 5.1.3 the command works as expected. If the the diag functionality is critical to you I recommend opening a TAC case.
Florian
Thank you for your comment.  I saw the bug database, but I was more concerned about the message "...no diag process running for the node or the node is not up."  I guess it is not very important message since everything shows as "UP" with the "sh platform" command.
