How can I configure AAA authentication on ASR9K?
Hi everyone,
I´m looking for how can I configure AAA authenticacion on ASR9K.
I have a TACACS+ server
Thanks and regards,
Jaime.
Ivan Krimmel
Level 7
Level 7
Vadim Zhovtanyuk
Hi Jaime,
here is the basic configuration:
tacacs-server host port 49
key 7 !
aaa group server tacacs+ acs-group
server
aaa authentication login acs-auth group acs-group local
line console
login authentication acs-auth
line default
An example:
RP/0/RSP1/CPU0:router#sh run tacacs-server
tacacs-server host 1.1.1.1 port 49
key 7 0822455D0A16544541
RP/0/RSP1/CPU0:router#sh run aaa group server tacacs+
server 1.1.1.1
RP/0/RSP1/CPU0:router#sh run aa authentication
RP/0/RSP1/CPU0:router#sh run line default
line default
exec-timeout 0 0
Thanks a lot.
Jaime.
If you're ready for the next level, you may want to check out this refernece also:
https://supportforums.cisco.com/docs/DOC-15944
xander
Xander Thuijs - CCIE #6775
Sr Tech Lead ASR9000
