HSRP NCS560
yfrolov
Hello colleagues
Please tell me.
Is it necessary to enter the 'hw-module vrrpscale enable' command to enable the hsrp function on the NSC560 and will the device need to be rebooted? I know that for NCS540 it is necessary
tkarnani
By default the platform has a 16 virtual mac limit that is shared amongst vrrp/hsrp, BVI and BFD protocols
when you exceed this limit the virtual mac will not be programmed in hardware, then you will need the command to increase the scale to 255.
you can check the current macs that are programmed in hardware via this command
show controllers fia diagshell <npu id> "dump IHP_VRID_MY_MAC_TCAM" location <>
