IOS-XR 100GbE and 10GbE Line Cards
Lyphiard
On some IOS-XR releases, I saw the note:
Cisco IOS XR Release 5.3.0 and later does not support combination of Cisco ASR 9000 High Density 100GE Ethernet Line Card and Cisco ASR 9000 Ethernet Line Card in a single chassis.
For the list of ASR 9000 Series line card types, see: http://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116726-qanda-product-00.html#anc2
Can someone please clarify exactly which line cards fall under the class "High Density 100GE"?
Would I be able to mix and match say a A9K-4X100GE-TR or A9K-2X100GE-TR with an A9K-24X10GE-TR line card?
2 Accepted Solutions
tkarnani
that note refers to not mixing trident and tomahawk based line cards
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116726-qanda-product-00.html
Trident/Tyhpoon are fine
Typhoon/Tomahawk (which you listed) are fine
Aleksandar Vidakovic
1st generation ethernet line card == Trident
2nd generation ethernet line card == Typhoon
3rd generation ethernet line card == Tomahawk
Trident and Typhoon in the same chassis ==> supported
Typhoon and Tomahawk in the same chassis ==> supported
Trident and Tomahawk in the same chassis ==> not supported
You can see here which PID belong to which family: https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116726-qanda-product-00.html
tkarnani
