IOS XR TCAM Region 3 has ran out of resources
ez9
I am getting the following error message on an ASR 9006 router "vlan_ea[396]: %ETHER_EA-3-TCAM_REGION_OOR : Error during TCAM allocation, TCAM Region 3 has ran out of resources"
How can I check which TCAM space/region is exhausted and how to check which is the upper limit?
9 Replies 9
tkarnani
you can check via this command, it will print each region
show prm server tcam summary all all all location 0/x/CPU0
ez9
I already run these commands but I didn't located the region. The output is the following:
show prm server tcam summary all all all location 0/0/CPU0
                Node: 0/0/CPU0:
TCAM summary for NP0:
  TCAM Logical Table: TCAM_LT_L2 (1)
    Partition ID: 0, priority: 2, valid entries: 1, free entries: 255
    Partition ID: 1, priority: 2, valid entries: 0, free entries: 256
    Partition ID: 2, priority: 0, valid entries: 0, free entries: 256
    Partition ID: 3, priority: 0, valid entries: 0, free entries: 4096
    Partition ID: 4, priority: 0, valid entries: 1, free entries: 19711
  TCAM Logical Table: TCAM_LT_ODS2 (2), free entries: 16443, resvd 128
    ACL Common Region: 0 entries allocated. 0 entries free
    Application ID: NP_APP_ID_IFIB (0)
      Total: 1 vmr_ids, 8005 active entries, 8005 allocated entries.
    Application ID: NP_APP_ID_QOS (1)
      Total: 0 vmr_ids, 0 active entries, 0 allocated entries.
    Application ID: NP_APP_ID_ACL (2)
    Application ID: NP_APP_ID_AFMON (3)
    Application ID: NP_APP_ID_LI (4)
    Application ID: NP_APP_ID_PBR (5)
  TCAM Logical Table: TCAM_LT_ODS8 (3), free entries: 3365, resvd 128
      Total: 1 vmr_ids, 603 active entries, 603 allocated entries.
    Application ID: NP_APP_ID_EDPL (6)
TCAM summary for NP1:
TCAM summary for NP2:
    Partition ID: 0, priority: 2, valid entries: 2, free entries: 254
    Partition ID: 3, priority: 0, valid entries: 3, free entries: 4093
TCAM summary for NP3:
show prm server tcam summary all all all location 0/1/CPU0
                Node: 0/1/CPU0:
    Partition ID: 3, priority: 0, valid entries: 4096, free entries: 0
    Partition ID: 4, priority: 0, valid entries: 4097, free entries: 15615
    Partition ID: 4, priority: 0, valid entries: 4095, free entries: 15617
ez9
I attach the output of the commands as my previous reply automatically deleted.  Can you please help me to identify the TCAM region?
tkarnani
NP0, LC1
you can see free entries are 0
show controller np ports all location 0/1/cpu0 << check the port mapping for np0
Partition 3; is usually used for l2interfaces please check the scale
ez9
Thank you for the info. Is there any specific location to check the scale? The line card is one A9K-2x100GE-TR
tkarnani
we can check show im database brief location 0/x/cpu0 , it should list all the interfaces
show controller np ports all location 0/1/cpu0 ; will show the interfaces mapped to the NPU0 which is reporting tcam full
ez9
Sorry for the misunderstanding, but i am referring to the scale of the platform. I indeed have 4096 l2transport subinterfaces. So, is this a generic scale limitation or it is only on my platform with A9K-2x100GE-TR LC?
tkarnani
The scale is per line card as the TCAM is on each line card.
each line card will have a different value for tcam space
ez9
Thanks for the answers. So, Is there any document that describes the partitions usage eg how did you know that the partition 3 is about l2transport interfaces? Is this documented somewhere?
