IOS XRv 6.1.1 NNI-Option-B Data Plane issue
Hemant Sharma
I have a setup where 2 IOS-XRv routers are Option-B NNI peers within a confederation.
The control plane works fine but the data plane is not forwarding any traffic received from the peer.
I ran a 'debug mpls drop' on ASB-18 and at the same time a ping test from CE-11 Lo0 to CE-12 Lo0, it says there is no label for the host but the output of 'show mpls forwarding' shows the label.
(11.0.1.1)(Lo0) CE-11 <<<PE-A<<Confed-A>>>>> ASB-17 <---> ASB-18 <<<<<Confed-B>>>PE-B>> CE-12 (Lo0)(12.0.1.1)
NOTE: This setup works in the live network but couldnt make it in simulation.
What did i miss? Please help
Please see the config and output below:
ASB-18 Configuration:
RP/0/0/CPU0:ASB-18#sh run router bgp
Sun Oct  9 23:10:45.838 UTC
router bgp 1017
 bgp confederation peers
  1015
  1020
 bgp confederation identifier 6789
 mpls activate
  interface GigabitEthernet0/0/0/1
 address-family vpnv4 unicast
  retain route-target all
 neighbor 5.5.5.5
  remote-as 1017
  update-source Loopback0
   next-hop-self
 neighbor 8.8.8.8
  remote-as 1020
  ebgp-multihop 255 mpls
   next-hop-self
 neighbor 10.0.150.17
  remote-as 1015
   next-hop-self
RP/0/0/CPU0:ASB-18#sh run router static
Sun Oct  9 23:10:51.138 UTC
router static
 address-family ipv4 unicast
  9.9.9.9/32 tunnel-te1809
  10.0.150.17/32 GigabitEthernet0/0/0/1
  10.10.10.10/32 tunnel-te1810
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:ASB-18#sh run mpls
Sun Oct  9 23:13:49.495 UTC
mpls traffic-eng
 interface GigabitEthernet0/0/0/0
mpls oam
RP/0/0/CPU0:ROW-ASB-18#sh bgp vpnv4 uni
Mon Oct 10 09:45:08.111 UTC
BGP router identifier 18.18.18.18, local AS number 1017
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0x0   RD version: 0
BGP main routing table version 29
BGP NSR Initial initsync version 9 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
              i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network            Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 6789:2020
*> 11.0.1.1/32        10.0.150.17              0    100      0 (1015) 64512 i
*>i12.0.1.1/32        9.9.9.9                  0    100      0 64512 i
*> 111.0.1.0/24       10.0.150.17                   100      0 (1015) i
*>i129.0.1.0/24       9.9.9.9                       100      0 i
Route Distinguisher: 6789:3030
*> 11.0.0.1/32        10.0.150.17              0    100      0 (1015) 64512 ?
*>i12.0.0.1/32        9.9.9.9                  0    100      0 64512 ?
*> 111.0.0.0/24       10.0.150.17                   100      0 (1015) i
*>i129.0.0.0/24       9.9.9.9                       100      0 i
Processed 8 prefixes, 8 paths
RP/0/0/CPU0:ROW-ASB-18#sh bgp vpnv4 uni sum
Mon Oct 10 09:45:15.041 UTC
BGP is operating in STANDALONE mode.
Process       RcvTblVer   bRIB/RIB   LabelVer  ImportVer  SendTblVer  StandbyVer
Speaker              29         29         29         29          29           0
Neighbor        Spk    AS MsgRcvd MsgSent   TblVer  InQ OutQ  Up/Down  St/PfxRcd
5.5.5.5           0 1017      23      23       29    0    0 00:12:49          4
8.8.8.8           0 1020      28      26       29    0    0 00:12:48          0
10.0.150.17       0 1015      24      27       29    0    0 00:12:48          4
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:ASB-18#debug mpls drop
Sun Oct  9 23:11:36.644 UTC
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:Oct  9 23:11:40.234 : netio[314]: [mpls_switch:2831] Pkt Drop: mpls_switch: GigabitEthernet0_0_0_1, No LFIB entry found for in_label 24003
RP/0/0/CPU0:Oct  9 23:11:42.204 : netio[314]: [mpls_switch:2831] Pkt Drop: mpls_switch: GigabitEthernet0_0_0_1, No LFIB entry found for in_label 24003
RP/0/0/CPU0:Oct  9 23:11:44.204 : netio[314]: [mpls_switch:2831] Pkt Drop: mpls_switch: GigabitEthernet0_0_0_1, No LFIB entry found for in_label 24003
RP/0/0/CPU0:Oct  9 23:11:46.194 : netio[314]: [mpls_switch:2831] Pkt Drop: mpls_switch: GigabitEthernet0_0_0_1, No LFIB entry found for in_label 24003
RP/0/0/CPU0:Oct  9 23:11:48.174 : netio[314]: [mpls_switch:2831] Pkt Drop: mpls_switch: GigabitEthernet0_0_0_1, No LFIB entry found for in_label 24003
RP/0/0/CPU0:ASB-18#sh mpls forwarding detail
Sun Oct  9 23:28:23.386 UTC
Local  Outgoing    Prefix             Outgoing     Next Hop        Bytes
Label  Label       or ID              Interface                    Switched
24000  Pop         10.0.150.17/32     Gi0/0/0/1    10.0.150.17     8870
     Updated: Oct  9 22:21:30.170
     Path Flags: 0x8 [  ]
     Version: 10, Priority: 4
     Label Stack (Top -> Bottom): { Imp-Null }
     NHID: 0x0, Encap-ID: N/A, Path idx: 0, Backup path idx: 0, Weight: 0
     MAC/Encaps: 14/14, MTU: 1500
     Packets Switched: 139
24003  131070      6789:2020:12.0.1.1/32   \
                                                   9.9.9.9         0
     Updated: Oct  9 22:46:19.768
     Path Flags: 0x6000 [  ]
     Label Stack (Top -> Bottom): { }
     MAC/Encaps: 0/0, MTU: 0
     Packets Switched: 0
24004  131070      6789:2020:129.0.1.0/24   \
                                                   9.9.9.9         0
     Packets Switched: 0
24005  131069      6789:3030:12.0.0.1/32   \
                                                   9.9.9.9         0
     Packets Switched: 0
24006  131069      6789:3030:129.0.0.0/24   \
                                                   9.9.9.9         0
     Packets Switched: 0
24007  24006       6789:2020:11.0.1.1/32   \
                                      Gi0/0/0/1    10.0.150.17     0
     Updated: Oct  9 22:46:30.387
     Version: 19, Priority: 4
     Label Stack (Top -> Bottom): { 24006 }
     MAC/Encaps: 14/18, MTU: 1500
     Packets Switched: 0
24008  24007       6789:2020:111.0.1.0/24   \
     Updated: Oct  9 22:46:30.417
     Version: 20, Priority: 4
     Label Stack (Top -> Bottom): { 24007 }
     Packets Switched: 0
24009  24008       6789:3030:11.0.0.1/32   \
     Version: 21, Priority: 4
     Label Stack (Top -> Bottom): { 24008 }
     Packets Switched: 0
24010  24009       6789:3030:111.0.0.0/24   \
     Version: 22, Priority: 4
     Label Stack (Top -> Bottom): { 24009 }
     Packets Switched: 0
24011  131071      6789:2020:13.0.1.1/32   \
                                                   10.10.10.10     0
     Updated: Oct  9 23:05:37.769
     Packets Switched: 0
24012  131071      6789:2020:130.0.1.0/24   \
                                                   10.10.10.10     0
     Packets Switched: 0
24013  131070      6789:3030:13.0.0.1/32   \
                                                   10.10.10.10     0
     Packets Switched: 0
24014  131070      6789:3030:130.0.0.0/24   \
                                                   10.10.10.10     0
     Packets Switched: 0
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:ASB-18#sh mpls forwarding tunnels detail
Sun Oct  9 23:22:55.658 UTC
Tunnel        Outgoing    Outgoing     Next Hop        Bytes
Name          Label       Interface                    Switched
tt1809            600         Gi0/0/0/0    10.0.140.6      0
     Updated: Oct  9 22:45:30.521
     Version: 12, Priority: 2
     Label Stack (Top -> Bottom): { 600 }
     Local Label: 24001
     Packets Switched: 0
  Interface Name: tunnel-te1809, Interface Handle: 0x00000090, Local Label: 24001
  Forwarding Class: 0, Weight: 0
  Packets/Bytes Switched: 0/0
tt1810            610         Gi0/0/0/0    10.0.140.6      0
     Updated: Oct  9 23:05:37.689
     Version: 54, Priority: 2
     Label Stack (Top -> Bottom): { 610 }
     Local Label: 24002
     Packets Switched: 0
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:ASB-18#sh mpls forwarding exact-route label 24003 ipv4 10.0.150.17 9.9.9.9
Sun Oct  9 23:31:44.472 UTC
                                                   point2point     N/A
     Via: NULLIFHNDL, Next Hop: special
     Label Stack (Top -> Bottom): { 131070 }
     MAC/Encaps: 0/4, MTU: 0
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:ASB-18#sh mpls traffic-eng forwarding
Sun Oct  9 23:43:24.424 UTC
P2P tunnels:
Tunnel ID                  Ingress IF     Egress IF      In lbl  Out lbl        Backup
18.18.18.18 1809_2                      -      Gi0/0/0/0 24001   600            unknown
18.18.18.18 1810_3                      -      Gi0/0/0/0 24002   610            unknown
Displayed 2 tunnel heads, 0 label P2P rewrites
Displayed 0 tunnel heads, 0 label P2MP rewrites
RP/0/0/CPU0:ASB-18#
RP/0/0/CPU0:ASB-18#
And then, there is this matter of Label Collision logs and I couldn't find any information about them
RP/0/0/CPU0:Oct  9 23:05:37.739 : bgp[1052]: %ROUTING-BGP-4-LABEL_COLLISION : Label 24012 collision: prev: [T: 11 RD:6789:2020 PFX/NHID:130.0.1.0/24] curr: [T: 11 RD:6789:2020 PFX/NHID:130.0.1.0/24]
RP/0/0/CPU0:Oct  9 23:05:37.749 : bgp[1052]: %ROUTING-BGP-4-LABEL_COLLISION : Label 24013 collision: prev: [T: 11 RD:6789:3030 PFX/NHID:13.0.0.1/32] curr: [T: 11 RD:6789:3030 PFX/NHID:13.0.0.1/32]
RP/0/0/CPU0:Oct  9 23:05:37.749 : bgp[1052]: %ROUTING-BGP-4-LABEL_COLLISION : Label 24014 collision: prev: [T: 11 RD:6789:3030 PFX/NHID:130.0.0.0/24] curr: [T: 11 RD:6789:3030 PFX/NHID:130.0.0.0/24]
ASB-17 Configuration:
RP/0/0/CPU0:ASB-17#sh run router bgp
Sun Oct  9 23:16:10.245 UTC
router bgp 1015
  1017
  1020
 mpls activate
 neighbor 2.2.2.2
  remote-as 1015
   next-hop-self
 neighbor 10.0.150.18
  remote-as 1017
   next-hop-self
RP/0/0/CPU0:ASB-17#sh run router static
Sun Oct  9 23:16:15.485 UTC
router static
  1.1.1.1/32 tunnel-te1701
  10.0.150.18/32 GigabitEthernet0/0/0/1
RP/0/0/CPU0:PE-ASB-17#sh bgp vpnv4 uni
Mon Oct 10 09:44:48.582 UTC
BGP router identifier 17.17.17.17, local AS number 1015
BGP main routing table version 33
*>i11.0.1.1/32        1.1.1.1                  0    100      0 64512 i
*> 12.0.1.1/32        10.0.150.18              0    100      0 (1017) 64512 i
*>i111.0.1.0/24       1.1.1.1                       100      0 i
*> 129.0.1.0/24       10.0.150.18                   100      0 (1017) i
*>i11.0.0.1/32        1.1.1.1                  0    100      0 64512 ?
*> 12.0.0.1/32        10.0.150.18              0    100      0 (1017) 64512 ?
*>i111.0.0.0/24       1.1.1.1                       100      0 i
*> 129.0.0.0/24       10.0.150.18                   100      0 (1017) i
RP/0/0/CPU0:ASB-17#
RP/0/0/CPU0:ASB-17#
RP/0/0/CPU0:ASB-17#
RP/0/0/CPU0:ASB-17#sh bgp vpnv4 uni sum
Mon Oct 10 09:45:21.640 UTC
Speaker              33         33         33         33          33           0
2.2.2.2           0 1015      23      23       33    0    0 00:13:14          4
10.0.150.18       0 1017      27      24       33    0    0 00:12:53          4
RP/0/0/CPU0:ASB-17#
RP/0/0/CPU0:ASB-17#sh run mpls
Sun Oct  9 23:16:19.715 UTC
mpls traffic-eng
mpls oam
RP/0/0/CPU0:ASB-17#
RP/0/0/CPU0:ASB-17#sh mpls forwarding
Sun Oct  9 23:16:39.443 UTC
24000  Pop         10.0.150.18/32     Gi0/0/0/1    10.0.150.18     11419
24002  24003       6789:2020:12.0.1.1/32   \
                                      Gi0/0/0/1    10.0.150.18     4160
24003  24004       6789:2020:129.0.1.0/24   \
                                      Gi0/0/0/1    10.0.150.18     0
24004  24005       6789:3030:12.0.0.1/32   \
24005  24006       6789:3030:129.0.0.0/24   \
24006  131070      6789:2020:11.0.1.1/32   \
                                                   1.1.1.1         0
24007  131070      6789:2020:111.0.1.0/24   \
                                                   1.1.1.1         0
24008  131069      6789:3030:11.0.0.1/32   \
                                                   1.1.1.1         0
24009  131069      6789:3030:111.0.0.0/24   \
                                                   1.1.1.1         0
24010  24011       6789:2020:13.0.1.1/32   \
24011  24012       6789:2020:130.0.1.0/24   \
24012  24013       6789:3030:13.0.0.1/32   \
24013  24014       6789:3030:130.0.0.0/24   \
RP/0/0/CPU0:ASB-17#
kiran.mk
I  am seeing this problem on my setup, did any of you manage to find a solution for this, please?
