ASR 9910 (eXR) Media/Memory Understanding
MariaSousa48787
Hi *,
i need to perform a deep media/memory analysis of our ASR 9910(eXR), with 6.6.3 version. But because this IOS-XR version it is a virtualized environment the allocation/partitions it is completely different from the normal IOS
And considering that each RSP5(TR/SE) has:
  • 16/24GB DRAM
  • 2x128GB SSDs
  • 8GB embedded USB
TOMAHAWK/LIGHTSPEED LC i don't know!
I need to know which commands can i use to see the Total/Available Memory for each DRAM/SSD/eUSB memory to check if our routers are on limit.
For example, with just sh filesystem and sho media commands i don't know how to perform the available memory for each type of media.
RP/0/RSP1/CPU0:CC-LAB01#sh filesystem
File Systems:
Size(b) Free(b) Type Flags Prefixes
3921260544 3913465856 harddisk rw harddiskb:
23653642240 19868442624 harddisk rw harddisk:
8121659392 6942281728 flash-disk rw disk0:
3921260544 3913465856 harddisk rw harddiska:
20507914240 20159836160 flash-disk rw apphost:
4061327360 4050694144 flash rw /misc/config
0 0 network rw ftp:
0 0 network rw tftp:
RP/0/RSP1/CPU0:CC-LAB01#sh media
Media Information for local node.
Partition Size Used Percent Avail
rootfs: 3.8G 2.6G 72% 1.1G
harddisk: 23G 3.6G 17% 18G
log: 3.8G 159M 5% 3.5G
config: 3.8G 11M 1% 3.6G
disk0: 7.6G 1.1G 16% 6.1G
harddiska: 3.7G 7.5M 1% 3.5G
apphost: 20G 332M 2% 18G
rootfs: = root file system (read-only)
log: = system log files (read-only)
config: = configuration storage (read-only)
Many thanks
Maria
8 Replies 8
you can use
#show platform ?
#show process memory ?
#show processes cpu ?
commands
Good luck
KB
here is the output of sh platform
RP/0/RSP1/CPU0:CC-LAB01#sh platform
Node Type State Config state
0/RSP0/CPU0 A9K-RSP5-TR(Standby) IOS XR RUN NSHUT
0/RSP1/CPU0 A9K-RSP5-TR(Active) IOS XR RUN NSHUT
0/FT0 ASR-9910-FAN OPERATIONAL NSHUT
0/FT1 ASR-9910-FAN OPERATIONAL NSHUT
0/0/CPU0 A9K-24X10GE-1G-TR IOS XR RUN NSHUT
0/1/CPU0 A9K-16X100GE-TR IOS XR RUN NSHUT
0/PT0 A9K-DC-PEM-V3 OPERATIONAL NSHUT
0/PT1 A9K-DC-PEM-V3 OPERATIONAL NSHUT
RP/0/RSP1/CPU0:CC-LAB01#sh platform ?
WORD Partially qualified location specification
security System Security details
vm platform VM information
| Output Modifiers
0/0 Fully qualified location specification
0/1 Fully qualified location specification
0/BPID0 Fully qualified location specification
0/FT0 Fully qualified location specification
0/FT1 Fully qualified location specification
0/PT0 Fully qualified location specification
0/PT1 Fully qualified location specification
0/RSP0 Fully qualified location specification
0/RSP1 Fully qualified location specification
<cr>
RP/0/RSP1/CPU0:CC-LAB01#sh platform 0/RSP0
Maria
check these  commands too.
after type ? symbol, you will see many suggestions and try them too.
Good luck
KB
tkarnani
from the XR VM
show media  - free harddisk space
show process memory detail - per process memory usage and limits
show watchdog - system total memory usage/limit
from the admin vm
show process memory - per process memory usage and limits
show memory_status - system total memory usage/limit
Hi  TKarnani,
thank you so much from your reply it help me a lot to have some extra commands to know the thresholds and limits!
After to read more posts in this community i understood that harddisks have partitions and aren't in mirror (https://community.cisco.com/t5/xr-os-and-platforms/disk-mirroring-asr9000-crs/td-p/2563095)
But, it rise me some more doubts! And i made "hundreds" of researches and probably i found my answers, and would i like if you or someone that read this post, kindly, could check the following tables and verify if am i correct.
And in resume the router(Virtualized Environment) has the following allocation internal memory:
- 2x SSD harddisks partitioned and the partitions are used depending we are analyzing IOS-XR VM, Admin VM or other existent VMS.
- 1x eUSB partitioned and the partitions, like the previous memory are used per different VMs
- dRAM:16GB utilization it is also distributed over the entire Virtual system
Thanks in advance
Maria
Hi Maria,
you can also review this ppt, it has an overview of the eXR solution
slide 12, the SSD/CPU are allocated to the host itself
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/R6BGArNQ/TECSPG-3001.pdf
MariaSousa48787
Hi Tkarnani,
could you, kindly, share the ppt or the link to it?
thanks in advance
Maria
